does any D series tranny work?
Old May 12, 2011 | 06:10 AM
zapzach's Avatar
Default does any D series tranny work?
i have a 90 civic std 4 speed. want to get a dx or si tranny. just wanted to know if i had to keep it 88-91 or can i get a 92-95 tranny, etc..
i know it has to be a cable transmission and not hydraulic. did they stop making cable transmissions around a certain year?
any help would be great, gotta get rid of this 4 speed bs.
Old May 12, 2011 | 06:45 AM
tunerEF9's Avatar
Default Re: does any D series tranny work?
the only tranny that will work is a 88-91 cable tranny any model besides the first gen integra one will work 92 on is hydraulic and would need a conversion but can still work hope this helps oh ya and some trannys have different spline count so it takes a different clutch..
Old May 12, 2011 | 10:12 AM
zapzach's Avatar
awesome, that helps out man. i think the 88 have a different spline count than the 89-91. so i pretty much need a tranny from a 89-91 crx/civic hf, dx or si.
Old May 12, 2011 | 06:48 PM
raffaelli's Avatar
I am not so sure about the spline count. But the early transmission dont have the same ribs in the shaft as the later ones do.
Old May 12, 2011 | 08:31 PM
tunerEF9's Avatar
no prob just remember to get the clutch for that year tranny and u will always be good...
Old May 13, 2011 | 03:29 AM
zapzach's Avatar
thanks guys.
Old May 13, 2011 | 03:30 AM
zapzach's Avatar
oh yeah, one more question. what if i run into a ZC tranny. will that bolt up to any d series?
Old May 13, 2011 | 06:17 AM
jlicrx's Avatar
the ZC transmission uses an intermediate axle shaft and equal length larger Integra type axles - the D15 blocks do not have bolt holes for bolting on the intermediate shaft, so the ZC won't work with a D15 unless you swap out the differential for one from an Si transmission in order to use the stock unequal length axles
Old May 13, 2011 | 06:54 AM
tunerEF9's Avatar
dohc jdm zc tranny bolts right up works perfect dont get a d16a1 dohc usdm zc tranny it doesnt work again thats a first gen integra all others work fine plus a jdm dohc zc tranny has an lsd bonus
Midori Green
Sep 9, 2007 09:58 AM
b18b1turbo
Dec 21, 2006 01:50 PM
Si Shane
May 15, 2005 11:54 AM
.Beaver
Dec 6, 2002 04:00 AM
