What spacer would i need
Old May 11, 2011 | 10:14 PM
cscdc5's Avatar
Default What spacer would i need
I have 17x7.5 with a 37 offset what spacer would i need to get that hella flush look
Old May 12, 2011 | 05:38 AM
turboteg2nv's Avatar
Default Re: What spacer would i need
Please drive yourself off a cliff.
Old May 12, 2011 | 07:01 AM
NEO_FOLLOWER2's Avatar
dude for real? hellaflush is the new rice except worse
messes up your suspension and wears your tires out uneven
try being hellafunctional
Old May 12, 2011 | 09:44 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Wanna know how I figure it out in my shop?
If you brought me your car I would take the rim off and put washers on the studs and fit the rims back on. I would add or subtract the washers until I found the right width. Then measure the washers.
And if you want to be hella flush you are doing it wrong... real ballars buy rims that are hella flush without spacers. And make sure you don't cheap out on cheap spacers you will get vibrations and shimmies at high speeds.
Old May 12, 2011 | 11:30 AM
cscdc5's Avatar
It's not like I'm goin for the stretched tire look or anything I have 225 40 but on my front the guy that had the car before me put a aura rl brake conversion on an used spaces to clear the wit the 37 offset wheels an it jus flushed the wheel up but its not all stupid jus wanted the same in the rear jus clean simple not all cambered out or anything
W
Old May 12, 2011 | 12:02 PM
Troof.
And make sure your lug nuts get the proper thread count, otherwise you'll want extended studs to go with the new spacers.
Justintaken
Jan 10, 2016 07:21 PM
jdmsleeper12
May 20, 2010 04:33 PM
iaintnogangster
Nov 18, 2009 11:34 PM
rewerbcrx
Nov 23, 2007 04:45 PM
theeogflip
15
Sep 11, 2005 02:46 PM
