Fastest all motor ITR on stock cams?
Paragraph Alert
I wanna know what the fast stock cam ITR's are running on street tires. I know a few of us are close if not in the 13's with only I/H/E.
< Shooting for the 13.7 area on stock cams and compression and thinks it is possible.
Paragraph Alert
bump up compression to 13.5:1 and you're good to go
Paragraph Alert
probably with a lot of weight reduction, some Hytech or SMS pipes. hell throw in slicks for good measure.
I ran 14.1 in my 4 door with ITR cams and stock GSR pistons, so i know 13's is definately posible for a car that is quite a bit lighter and has higher compression. I also had crappy 2.2 60ft times when i ran that.
power in my sig was the motor in my civic, not teg.
Paragraph Alert
What I'm basically getting at is that I know of a couple of very lightly modded R's that are churning out times close to those that have tuned aftermarket cam setups and I'm wondering if there are any other stock cam/compression Type-R guys out there who's times I haven't seen.
13.7 is obtainable with slicks...stock car.
if you strip the living hell out of your car, you too can run high 13's.
im talking about removing 400 lbs + from the car.
nikanoras
Feb 16, 2010 10:26 PM
EKstacy
21
Jan 7, 2008 03:34 PM
MJobe
20
Mar 30, 2006 07:16 PM
