Please look over my junkyard turbo setup and give advice
Turbo will be going on a first gen b16a running 7 lbs I hope to push it to 10-12 in the future.
T3 with 63 a/r turbine and 60 a/r compressor w/ internal WG(will this turbo run out of steam or spool to slow)
hks manifold
hondata s200
dsm 450 injectors w/ resistor box
intank fuel pump (which one should i get and will stock work)
1G DSM BOV
JC Whitney charge pipes and down pipe. (what size charge pipe should i use)
Custom intercooler
Anything i'm missing
hks manifold
hondata s200
1G DSM BOV
Custom intercooler
sounds good, but I think you should upgrade your stock fuel pump just to be on the safe side...as for the turbo, its fine..and for the charge pipes, everyones opinions differ about the sizes...so I guess we'll just have to wait to see what others might think..but so far, sounds like you've got it all covered..Dont forget small things like lines, fittings, couplings, clamps, oil, stuff like that..good luck
Looks good. Fuel management looks good. Just get a Walbro 255lph intank and you'll be set. The T3 should spool nicely on the B16, and should fall too hard in the upper end. If you're going to be doing 7psi daily and up to 10-11; I would suggest 2.25"-2.5" piping. It kind of depends on your DP/exhaust setup. What kind of DP are you using, and what is your exhaust? You'll love the DSM BOV btw,
jB
jB
Thanks for the input and keep it coming
Did you mean "shouldn't" If not which turbo do you sudgest? I plan on doing a custom 2.5 or maybe 3 inch dp and exaust
jB
TrueUntilDeath.com
Aug 19, 2004 10:20 PM
