Remote MAP Sensor Mounting
Old May 11, 2011 | 05:40 PM
wEaK Squad *ATL*'s Avatar
Default Remote MAP Sensor Mounting
Anyone know who makes a remote MAP sensor adapter plate? There use to be a few available I remember but I'm have a hard time finding one now. Something similar to the red one shown half way down the page.
http://www.s2ki.com/s2000/topic/8556...ting-sensors/#
Old May 11, 2011 | 05:47 PM
GhostAccord's Avatar
Default Re: Remote MAP Sensor Mounting
You could use the OEM "remote" firewall mounted MAP sensor & bracket from a 90-93 Accord / Civic.
Old May 11, 2011 | 05:54 PM
But is the plug the same as a obd2 gsr harness?
Old May 11, 2011 | 07:39 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
you can use a ef map sensor or Im pretty sure a standard one will work just run the vac hose onto the nipple and zip tie it tight just for good measure. iv done it plenty of times without any issues.
Old May 11, 2011 | 08:03 PM
SL0WEGG's Avatar
My map sensor is just your regular old firewall mounted ones that come in 92 vx/cx models I believe. Works fine, I don't even have the hose zip tied and its never come off. Even the regular one that mounts on the TB could probably be used, just zip tie the hose if you're worried about that.
Old May 12, 2011 | 02:42 AM
Anyone know if the EG map sensor will plug into a obd2 harness??
Old May 12, 2011 | 10:39 AM
Loved
Community Favorite
ya there are the same...
Old May 13, 2011 | 11:49 PM
jdmcx's Avatar
using an h23 TB on my lsvtec map sensor is mounted on the firewall with a bracket i fabbed up to look like factory.
oksblue
Mar 31, 2013 03:59 PM
droppedeg6hatch
Jan 9, 2008 07:38 PM
93dabeast
May 23, 2007 04:24 AM
SOHC_DK.
May 6, 2004 07:43 AM
