d16y8 engine harness fit on b16a2?
Old May 11, 2011 | 04:26 PM
honda_hackett's Avatar
Default d16y8 engine harness fit on b16a2?
so i have a 99 civic ex w/ a stock d16y8(obd2) in it. i just picked up a b16a2(obd2) swap and was wondering if the engine harness on my sohc will work on the b16. i believe the plugs are exactly the same, i think i have to possibly lengthen/shorten the wires to make the harness fit. does anyone know for sure?
Old May 11, 2011 | 05:00 PM
apexi_rsx's Avatar
Default Re: d16y8 engine harness fit on b16a2?
when ever u do any swap u use the harness that's in the car some wires may need lengthened or shortened other then that this should be plug and play.. good luck your going to want to run obd1 if u want to tune it or boost it. if u stay obd2 u can not tune but u can use a stock b16 ecu if u just add bolt ons.
Old May 12, 2011 | 06:14 PM
thx apexi and i will def be converting to obd1 eventually
moshe eliyahu
Engine Management and Tuning
Jun 29, 2014 04:59 PM
drummerdude
Aug 13, 2010 09:51 AM
oneforce
Apr 24, 2006 10:21 AM
goat442003
Jun 21, 2003 07:16 PM
