lug pattern/ abs problem???
ok i have a problem i went outside today to check my abs code and it said 3 nothing else just 3. my book said its pulsars and i have no idea where they are and how to check them. but it says that they are on all four sides so while i was cleaning the back speed sensors . i decided to rotate my tires well my back tires won't fit on my front studs. the pattern is to small by a couple inches and my back tires are size p16070/r13. the fronts are p18560/r14 the back end are disc brakes not drums is this stock or is some thing off here.
If it was modified I am unaware of it I just know that the civic comes with drums and disk brakes. But I am pretty sure honda doesnt ship the car out with two different lug patterns and rims&tires so I am gonna assume it was a swap and if it was could the awap be why abs light is on and the lug patterm is different? How would u measure a lug pattern ?
So you bought the car with rims bigger in the front and didn't think to ask about it? Anyway your rears are probably 4x100 and the fronts are 4x114.3-probably off of an accord or Prelude.
This weird swap might also explain why your ABS has issues.
http://www.vehicle-bolt-pattern.com/...nce-guide.html
95 integra
May 20, 2004 03:31 AM
