gsr block with a ls crank
Old May 11, 2011 | 01:26 AM
acura_b18c1's Avatar
Default gsr block with a ls crank
sup , i have a gsr b18c1 block in my garage. it has no crank , but does come with the main caps and girdle. i was thinking about buying a ls b18b crank since its cheaper , easier to find , and gives it a slight displacement increase. i have a few questions :
- can i use the gsr main caps with the ls crank or do i need to find ls main caps ?
- if i can use the gsr main caps , can i use the girdle with no mods ?
- im guessing i need the gsr windage tray , gsr oil pickup, and gsr oil pan ?
- will using gsr sized rods push the pistons above the block ? ( meaning i need ls rods ? )
- is it recommended that i re use the oil squirters by bending it or should i jus get rid of it ?
thanks !
Old May 11, 2011 | 04:24 AM
turbodcxbro's Avatar
Default Re: gsr block with a ls crank
Dude this has been covered on here soooo many times! Search and you will find!
You have to remove the squirters and use LS rods...
Old May 11, 2011 | 07:45 AM
m_shake's Avatar
Search!!! And fyi, NEVER swap main caps between blocks and never buy a block without main caps..
Old May 11, 2011 | 11:23 AM
90efhatch's Avatar
What he said, there are a couple of good threads on this already.
This one has some good info.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ls-crank-rods-gsr-block-possible-1837872/
Old May 11, 2011 | 12:46 PM
thanks i jus read through all 15 pages !
egboy94
Feb 20, 2009 05:23 PM
ebrakeracin4
Jan 26, 2005 02:15 PM
ferio 95
Oct 7, 2004 08:58 AM
SM 30 Hatch
Oct 7, 2004 04:12 AM
MTP04
Jan 2, 2003 04:30 PM
