Mini-Me. What octane to use?
Old May 10, 2011 | 09:47 PM
r22thomas's Avatar
Default Mini-Me. What octane to use?
So I just finished my mini me. D16z6 head on a D15B7 block with y8 head gasket, and was wondering what octane gas I should use. Some people said the compression was around 11:1 others said around 10:1. Some people said 87 octane was ok, others said I have to run 89. So which one should I run?
Old May 10, 2011 | 10:24 PM
owneyboy's Avatar
Default Re: Mini-Me. What octane to use?
compression ratio should be around 10.2-10.5.. you can use pretty much all pump gas octanes whats the point to your question
Old May 10, 2011 | 10:25 PM
scythe88's Avatar
just go 89 to be safe.
Old May 10, 2011 | 11:00 PM
Townson's Avatar
quoting my late grandpa here: "gas is gas, dont let em fool ya" lol. but in all seriousness, you can try 87 and if it acts up then switch to mid-grade and so on.
Old May 10, 2011 | 11:15 PM
EJ1_Can2's Avatar
i ran regular on my mini me when i had it ran fine
Old May 11, 2011 | 04:21 AM
Crashtestdummy's Avatar
i know on my high comp ls i had 89 would ping during the summer but ran fine during the winter.
Old May 11, 2011 | 10:32 AM
r22thomas's Avatar
so 87 should be ok then?
Old May 11, 2011 | 10:34 AM
well run it and listen to see if it pings when it gets under a load, mine was very noticeable when it was pinging cause of the fuel grade. If it doesn't you should be fine.
Old May 11, 2011 | 10:42 AM
chope045's Avatar
my mini me is the same set up as yours i have 10.3:1 comp i always run 93 if i dont my motor pings
Old May 11, 2011 | 10:59 AM
r22thomas's Avatar
dang is the pinging sound a ping or a knock or a tap? haha if that makes sence
Old May 11, 2011 | 12:37 PM
Ayyxbro's Avatar
its up to you, running 87 isnt going to kill your car, i run it on my mini. But obviously 93 is going to be better for your car in the long run.
Personally i run 87 because its just a mini-me. Ill start running high octane when i throw a bigger engine in.
Old May 11, 2011 | 12:42 PM
strategy400's Avatar
Maybe colder plugs would help.
Dre90
Mar 28, 2010 07:43 PM
redcoats1976
43
Jul 11, 2008 08:06 PM
Cuong-nutz
Mar 6, 2005 08:26 AM
I3ackfire
May 16, 2004 01:39 PM
sal_blkej2
May 20, 2003 01:20 PM
