alignment
Old May 10, 2011 | 07:25 PM
dunckeldustin's Avatar
Default alignment
why is this like this? one wheel closer to bottom corner on driver side.
how can i fix it?
please help?
Last edited by It Wasn't Me; May 10, 2011 at 08:37 PM. Reason: Fixed image coding.
Old May 10, 2011 | 08:39 PM
It Wasn't Me's Avatar
Default Re: alignment
I corrected your image coding.
To learn how to post pictures, click the following link. https://honda-tech.com/forums/showthread.php?t=2860092
Was that car involved in an accident?
Old May 11, 2011 | 07:39 AM
Tyson's Avatar
You have a bent control arm, stretched radius rod, broken crossmember and any or all of the above.
Take your car to a shop to evaluate what exactly needs replaced.
Old May 14, 2011 | 03:54 PM
no it has a clean title? i just dont understand how this could have happend then. must not have been reported if so?
Old May 14, 2011 | 06:47 PM
Tyson's Avatar
Because it looks like it was run into a curb... A dumb mistake like that isn't going to be recorded on a title.
Old May 15, 2011 | 06:18 AM
ascarberry's Avatar
mine is the same way not quite as bad and after putting it up on the lift 4-5 times i still cant find what is bent!!!
Old May 15, 2011 | 07:17 AM
dr_latino999's Avatar
I'm with Tyson.
First time I've said that. Check where the LCA bolts to the rear crossmember, after a curb impact it likes to bend backwards.
Old May 22, 2011 | 12:50 AM
yeah man i must be blind. im going to get it checked out
Old Jun 19, 2011 | 08:28 PM
it was a streched/bent radiu\s rod
chino2x2x2x
Jun 22, 2007 12:03 PM
jdmcivicsi522
Jul 23, 2006 09:49 AM
JC19
Apr 25, 2004 11:27 PM
spettinger
Audio / Security / Video
Jun 28, 2003 02:28 AM
