Just installed ES Shifter Bushings
Old Sep 29, 2002 | 08:56 PM
axnpacked's Avatar
Default Just installed ES Shifter Bushings
Ordered them from suspension.com for about $12 bucks shipped. Taking the old bushings out were a piece of cake, putting them back on required a little elbow grease, but was still much much easier than I thought it would be. The whole process took like 20 minutes (excluding jacking up the cars). The pictures on one of the threads here was very helpful (https://honda-tech.com/zerothread?id=157977).
As far as how the they feel, I can't tell hardly any difference in the shifting from when I had the original rubber shifter bushings. It does feel a _little_ bit more precise and defined, but it feels just as smooth and easy to shift as before. Maybe I didn't tighten them enough?
Not bad for $12 bucks, but I sort of expected stiffer and more defined shifting feel.
Old Sep 29, 2002 | 09:08 PM
Dr Pooface's Avatar
Default Re: Just installed ES Shifter Bushings (axnpacked)
Mine made a big difference.
Old Sep 29, 2002 | 09:09 PM
B2FiNiTY's Avatar
Shouldn't be a night and day difference. It does help out a tad bit though.
Tommy_Gunns's Avatar
Default Re: Just installed ES Shifter Bushings (Dr Pooface)
Same here
Old Sep 29, 2002 | 09:11 PM
axnpacked's Avatar
Default Re: Just installed ES Shifter Bushings (Tommy_Gunns)
Is that with your stock shifter or a short shifter?
hungsteR's Avatar
For those who have installed them what years were your cars? How miles were on your car when you installed them?
Old Sep 29, 2002 | 09:13 PM
ZygSpeed's Avatar
Default Re: Just installed ES Shifter Bushings (hungsteR)
Probably makes a bigger difference when installed in conjunction with engine mount inserts.
Old Sep 29, 2002 | 10:10 PM
Both. I had it on with my short shifter and I had it on with my stock shifter. Notice-able difference in both cases.
Old Sep 29, 2002 | 10:11 PM
axnpacked's Avatar
50k miles on the engine.
When you guys say you feel a big difference, do you mean the shifter is stiffer or more precise?
Old Sep 29, 2002 | 10:15 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Well if you car is relatively new I doubt the difference would be that dramatic compared to cars that have had the crap kicked out of them. For $12 it is a worthy mod in my opinion.
Old Sep 29, 2002 | 10:22 PM
Default Re: Just installed ES Shifter Bushings (ActiveAero Ninja Edition)
I consider it the best mod under $20 (I got mine for about $10 USD).
Old Sep 30, 2002 | 12:09 AM
B2FiNiTY's Avatar
I consider it one of the hardest mod you can do under $20.
[Modified by ExOdy, 1:09 AM 9/30/2002]
Old Sep 30, 2002 | 12:32 AM
Rhetoric's Avatar
Default Re: Just installed ES Shifter Bushings (ExOdy)
I too have the ES bushings with the skunk2 shifter. I swapped the stock Itr shifter/bushings out, basically feels the same. I little firmer with the bushings, nothing 'incredible' about it. My buddy has a C's in his Itr, that one is a night and day difference.
rsangha13
Transmission & Drivetrain
Apr 4, 2013 06:30 AM
The_Honda_Guy
16
Nov 28, 2009 06:09 PM
turbotime
May 4, 2006 10:15 PM
eluder33
Nov 20, 2004 03:05 PM
_BEN_
Sep 23, 2002 07:47 AM
