Ground strap is fine for valve cover ground?
Old May 10, 2011 | 01:10 PM
ezcape's Avatar
Default Ground strap is fine for valve cover ground?
I'm looking to ground my valve cover to the frame. But don't have any extra grouns laying around would a "ground strap" from autozone work as well?
Old May 10, 2011 | 03:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ground strap is fine for valve cover ground?
Yes. 94
Old May 10, 2011 | 03:37 PM
ezcape's Avatar
Is it important to have? Car never came with one when I got it, but figured I put one there anyway.
Old May 10, 2011 | 06:50 PM
sc34dc4's Avatar
Yes it comes factory installed. Doesn't have to be on the front but you should have one from the VC to the chassis.
Old May 10, 2011 | 09:09 PM
Spawne32's Avatar
theres multiple engine ground points, but its good to keep all the factory locations in place, they are all merely wires of various sorts connecting two points of contact, you just have to make sure the wire is a sufficient size. Usually 14g or better on that valve cover ground.
Old May 10, 2011 | 10:52 PM
djkobe's Avatar
get a foot or so of some 10g wire and crimp some connectors on the end and call it a day. heat shrink over the plastic pieces of the connectors if you want it to have that clean look
civicgsr499
Jun 5, 2009 11:41 AM
chatman_55
Mar 17, 2009 08:05 PM
Razr2
Oct 15, 2008 06:31 AM
GeorgeJetson
10
Jan 16, 2004 09:54 AM
AutoXsi2000
Jun 21, 2002 11:13 AM
