Rough start ups with vid
Lately my starts have been really rough, and struggles to catch, and remain idling.
The fuel pump turns on, car turns over fine but doesn't want to run by itself...if that makes sense?
New factory plugs, fuel filter, timing has been triple checked by Acura, new grounds and terminals cleaned, compression is good, swapped in a different starter, battery is over 12V when starting up, injectors have been cleaned and flowed, fuel pressure is 42psi, no CEL's.
Dumb me I forgot to turn the dash lights on but you can hear everything fine, even my pre-workout metal tunes
Doesn't sound like a main relay problem, because the fuel pump kicks on...
Suggestions?
Suggestions?
When you say that Acura has checked the timing, are you referring to both ignition and cam timing? The fact that no CEL's pop up strongly suggest that it's a mechanical issue (ie cam timing) rather than being related to a sensor. Not saying that it is or isn't, just suggesting a troubleshooting route.
You can disable the fuel pump and crank the car while checking for quality of spark at the plugs (pull out and ground one at a time to the head). I wouldn't waste my money on a new distributor just yet, though a new cap and rotor certainly worth break the bank or hurt things at this point. Inspect your wires while you're at it. There are ways to check the distributor/ignitor as well using only a multimeter (search).
Did this start happening soon after getting new gas? What was done or what changed around the time it started happening? Post your mileage also.
I recently bought a brand new rotor and cap from Acura and ran fine with them in for a while. They are about 3 months old.
Ill do a resistance check on my wires, but they are new oem wires as well...
Didn't happen after getting new gas, happened slowly and progressively got worse and worse. Wasn't just an over night thing.
I brought up a separate issue of getting very bad mileage in this thread https://honda-tech.com/forums/acura-integra-type-r-8/horrible-fuel-comsumption-2920189/
Seems like my spark isn't strong enough which is leading to the break up on start ups and leading to poor mileage?
Ill check my helms manual for testing and checking the distributor. Any specific tests you recommend besides disabling the fuel pump and checking the spark plugs against the head?
My R is going through the same issues. It's mainly after the car sits for an extended period of time or if I go to a few places only a couple miles apart and have to start and stop the engine. I have a thread too and have replaced many of the parts mentioned.
Did you clean the IACV?
Im getting really fed up and buying a newer distributor tomorrow, and ill have replaced almost everything! Ill report back when I get it installed and the timing checked on it again.
does it smoke after it starts? i couldnt tell how much it was hesitating when started. ive seen an injector getting stuck cause similar situation, the cylinder gets a bunch of fuel in it when the cars off and has trouble starting because its flooded
Haven't gotten around to it, most likely will tackle that this weekend!
I can try swapping back over to my other injectors.
Picked up the distributor but waiting for a shop to install it properly with a timing gun. Hoping for today.
How old are your spark plugs?
What did you gap them to?
You said that the fuel pressure was checked with a mechanical gauge, correct?
It sounds like it's starving for fuel. Almost like my cold E85 starts.
Mechanical gauge has been on for a couple weeks and reads 42psi while idling.
Im going to double check the plug gaps. Don't see how they could have expanded over time...but its worth a look.
Check your oil pump bro. It might be taking a **** on u. Kinda sounds like what was happening to my R. Take the the valve cover off and see if oil is squirting up there. Hope this helps
