need some help with idle issue
Old May 10, 2011 | 08:03 AM
19EF91's Avatar
Default idle issue is ping me off and need it fixed
so when i come to a stop light my idle drops real low and when i go to take off it sputters until i get in a little higher rpms i put a new iacv on not to long ago and it still does it
my car is a 91 hatch and i put a d16z6 i rewire the car over to multi port and im useing a 89 si dizzy and si computer and i have know clue what it is im not geting any codes at all other then the o2 sencor once in a while
Old May 10, 2011 | 10:07 AM
ef_cowboy's Avatar
Default Re: need some help with idle issue
try adjusting the screw on the tb that controls idle
Old May 10, 2011 | 11:28 AM
bk7794's Avatar
I don't recommend screwing with the idle screw unless I would know it was the cause.
Does this happen under all weather conditions? The o2 sensor could be the issue, cause it might not throw a code, its just getting less accurate.
Old May 10, 2011 | 07:17 PM
19EF91's Avatar
i put a new oem o2 in not to long ago i had new vavle silse in my head it might be the prob i did a compression test and im 180 all the way across i have new piston ring to put in but im debating on just geting a new head
Old May 10, 2011 | 08:40 PM
zach53's Avatar
check ur vacuum hose that connects to the pvc valve on the mani
Old May 11, 2011 | 02:13 AM
singlecamsaint's Avatar
also check your timing the mini me i just built was doing this crap it was one tooth retarded by the cam gear moved it forward a tooth and bingo
Last edited by singlecamsaint; May 11, 2011 at 02:13 AM. Reason: replaced a word lol
Old May 11, 2011 | 06:22 AM
19EF91's Avatar
i hate doing time becase every time i do it it it moves on me when i try to put the belt on the came gear so if there s a better way to do it ill do it that way
19EF91
May 15, 2011 06:19 AM
kpop
Feb 18, 2008 04:40 PM
vi3tromanc3r
37
Jun 25, 2007 08:12 PM
mr. carpenter
Feb 8, 2004 12:03 PM
vtecjb
Jan 26, 2004 07:55 AM
