VTEC wiring.......
Old Sep 29, 2002 | 08:28 PM
flat-blk-HB's Avatar
Default VTEC wiring.......
Ok I am wondering @ the ECU in a 92 Civic when I am wiring VTEC do I cut the wire completey and run the VTEC wire off it OR do I just tap into the wire itself...I know soooooo many people are going to tell me that the VTEC wire is already there and all but I just want to know about the VTEC wiring thing so I can get rid of this nasty CEL I have...And VTEC will work of corse.. ..Currently I have it just tapped in and the "VTEC light" I wired up is not turing on so I am thinking something is messed up with the wiring..
Old Sep 29, 2002 | 08:56 PM
Kamin's Avatar
Default Re: VTEC wiring....... (!)
the wire is there.
Old Sep 29, 2002 | 09:11 PM
Default Re: VTEC wiring....... (KAMiN)
Ok I know what you are saying and I have been told that the 92 have the VTEC wire already there..Well i am using a 94-95 DX harness so I would have the 4 wire o2..Anyways is there a link to a site or can you tell me step by step on how to make my VTEC work..Thanks for all the help..
Old Sep 30, 2002 | 07:35 AM
Bump
Old Sep 30, 2002 | 08:33 AM
92sleepR's Avatar
New User
The Helms manual has a thoroughly detailed wiring diagram of the system. It's absolutely necessary if you are trying to diagnose a problem. Kamin is right, all the necessary wires are there. The only thing you would need to add is a wire for the IAB system (assuming you have a GSR engine)
If what you are asking though is how to move wires around at the ECU plugs you can cut and re-solder them but I prefer to move the pins themselves. The wires should run from the ECU directly to where they need to go. VTEC solenoid, pin A4. VTEC pressure switch, pin D6
Mike
Old Sep 30, 2002 | 06:56 PM
Default Re: VTEC wiring....... (92sleepR)
Thanks guys I got it fixed and VTEC is working properly..... Now on to other problems, thanks for the help...
Acidcrakker
Nov 8, 2007 02:39 PM
STUCKED
Mar 7, 2007 04:51 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
BluntMan
Jan 3, 2003 09:23 AM
