91 civic starting issue
Old May 9, 2011 | 11:01 PM
hell_sol's Avatar
Default 91 civic starting issue
When you turn the key to start the car, all the lights come on and stay on but it won't start. No cranking or anything.
I thought my ignition switch went bad, but i replaced that and it still won't start.
I checked the fuses and they're fine. I'm really stumped...
Old May 9, 2011 | 11:11 PM
88LsRex's Avatar
Default Re: 91 civic starting issue
Check Your grounds.
Main Relay.
Or push your Key in a little when you turn it over.
Mine did the same exact thing.
Old May 9, 2011 | 11:28 PM
hell_sol's Avatar
Originally Posted by 88LsRex
Check Your grounds.
Main Relay.
Could it be the ground wire that bolts to the top of the valve cover and then runs straight across to the frame ? I was messing with that the other day, so does that wire have anything to do with the engine starting ?
Is the main relay located to the left of the interior fuse box ?
Old May 9, 2011 | 11:54 PM
88LsRex's Avatar
Check the Ground on the starter.
and yeah..
Try the key thing haha
Old May 10, 2011 | 12:04 AM
zach53's Avatar
yea the main relay is left of the fuse box and no my civic ran forever w/o that ground you are talkin about and rex is right check the ground on the starter..but it sounds to me like its the main relay....easy fix bro
Old May 10, 2011 | 12:21 AM
88LsRex's Avatar
Yeah get one from a junk yard or just buy a new one. there like 40 bucks
Old May 11, 2011 | 08:20 AM
hell_sol's Avatar
Thanks for the replies everybody.
I had my brother come over ( mechanic ) and he concurs. It's the main relay, but we're still unable to locate it. I checked all the relays that i could see that were near the interior fuse box.
Old May 11, 2011 | 08:25 AM
88LsRex's Avatar
Your "mechanic" brother cant find your main relay?
Old May 11, 2011 | 08:30 AM
hell_sol's Avatar
He works on forklifts.
He's really good at what he does too. Just not used to Hondas.
Old May 11, 2011 | 10:18 AM
hell_sol's Avatar
Please help !
I'm so close, all i need to do is find this relay.
Old May 11, 2011 | 02:10 PM
slywfbpsi's Avatar
main relay is to the left of the fust box. I just changed mine a few minutes again, because my car would not start.
nolo
May 21, 2022 02:03 PM
jdreadjdm
Jul 1, 2012 04:35 PM
BlazeTeck2000
Dec 8, 2005 03:39 PM
torr
Apr 11, 2005 03:58 AM
tgod1020
Jul 5, 2004 10:21 AM
