B18c1 running hotter than normal
Old May 9, 2011 | 09:56 PM
jAyee124's Avatar
Post B18c running hotter than normal
B18c with Koyo aluminum radiator. Normally it runs in the 190F range and will sit about 200-205F range during long stops or after running it hard..until a few days ago.. Now its bouncing around 205-220F and will sit a 225-230F during long stops. Oil levels are good, coolant level is good and no signs of head gasket problems. Anyone have any ideas?
Old May 9, 2011 | 10:22 PM
hmongyaj87's Avatar
Default Re: B18c1 running hotter than normal
bump.. my gsr seems to be running hotter as usual too. I also have a dual core aluminium radiator.
Old May 10, 2011 | 12:39 AM
jAyee124's Avatar
Icon3 Re: B18c1 running hotter than normal
what also worries me is that my water temp gauge only goes to 250F. Getting pretty close!
Old May 10, 2011 | 02:53 AM
EnjoyTheRideDC2's Avatar
Originally Posted by jAyee124
B18c1 is in a 95 EJ1 with a Koyo aluminum radiator. Normally it runs in the 190F range and will sit about 200-205F range during long stops or after running it hard..until a few days ago.. Now its bouncing around 205-220F and will sit a 225-230F during long stops. Oil levels are good, coolant level is good and no signs of head gasket problems. Anyone have any ideas?
Maybe your fan switch is bad?
Maybe your T-stat is not opening up when it should and needs replacement?
Old May 10, 2011 | 04:45 AM
Superide's Avatar
could it be any air in the system?
Old May 10, 2011 | 05:11 AM
vtecdc4's Avatar
check if your cooling fan turns on,
check t-stat
bleed coolant system
Old May 10, 2011 | 01:57 PM
jAyee124's Avatar
thanks
Old May 10, 2011 | 06:07 PM
jAyee124's Avatar
coolant flushed taking her out
Old May 10, 2011 | 08:40 PM
jAyee124's Avatar
She's running fine now! Still not sure what the exact problem was. Thanks
colbynorwood
May 18, 2013 05:57 AM
project-boosteD
Jun 29, 2011 12:25 PM
Lucky_Smurf
Aug 23, 2005 09:46 AM
dabrown
May 23, 2004 01:58 PM
carl_aka_carlos
Apr 1, 2004 11:16 AM
