EF Sedan Problems
Old May 9, 2011 | 07:56 PM
Putt Putt's Avatar
Default EF Sedan Problems
Well I just added some motor oil and my car started to give off a really hard vibration. I never had any problems with the motor. Since the day it been swap, But i got a feeling it's the motor mount cause form my view my motor appearance didn't look right.
Old May 9, 2011 | 10:44 PM
Putt Putt's Avatar
Default Re: EF Sedan Problems
if anyone can give me any help it would be nice. thanks in advance
Old May 9, 2011 | 10:47 PM
codybuRr's Avatar
your going to have to give a little more info than a "hard vibration" lol.
that could be many things. especially a 20 year old car.
Old May 9, 2011 | 10:52 PM
alex14's Avatar
Your post doesnt make sense. It doesnt ask any kind of question or state any specific problem. If you want help, you have to explain yourself better. "I put oil in it and now it shakes hard"
putting oil in your car doesnt make it shake hard. Could be bad mounts, could be a misfire, could be a lot of things.
Old May 9, 2011 | 11:09 PM
Putt Putt's Avatar
Sorry I well.
To give you a full story of information.
I went to 7-11 cause I was low on motor oil. So I added a little bit more motor oil . After that I started the car before I left the gas station, at that time the car started to give a loud vibrating response. which was kinda weird cause the car was working fine before I enter the parking lot. So I drove the car back home and that's when I started to notice that the vibration would go away when I accelerated, but when I would take my foot off the gas the vibration would start up again. I check everything in the motor everything look fine except my motor look kinda crooked. So it got me thinking it might be bad worn out motor mounts. I could I be wrong?
Old May 9, 2011 | 11:53 PM
zach53's Avatar
Originally Posted by Putt Putt
Sorry I well.
its easy dude obviously u should noe where ur mounts are so get under the car and look....the front mount will be easier 2 see then the one in the back also it may not have anything to do with the motor a loud vibration can also be caused by a wheel bearing... hope this helped
Old May 10, 2011 | 12:18 AM
Putt Putt's Avatar
yea thanks and one more question. When i shifting in to gear. I get this thud sound <Like when someone pounds there fist in to the wall>. do you know what maybe the cause of that? the tranny i got in the ef is a 2000 civic si tranny with a SOHC ZC 1.6 Motor. The clutch grabs pretty hard when i push the car, during those times mostly like your right about the motor mounts cause i am looking at them at this very moment
Old May 10, 2011 | 12:40 AM
Putt Putt's Avatar
this is the current stance of the Motor.
Old May 10, 2011 | 05:35 AM
BiG ChOr!Zo's Avatar
^lol
mounts toast yo
Old May 10, 2011 | 06:08 AM
alex14's Avatar
Either the mounts are bad or they have unbolted themselves. My rear mount likes to slowly unscrew itself on occasion. it results in "clunky" feelings when i shift.
Old May 10, 2011 | 11:38 AM
Putt Putt's Avatar
Yea you was right about that man. I check and notice that I was missing 2 bolts.
Old May 10, 2011 | 05:49 PM
zach53's Avatar
YEA it sounds like a mount 4sure!!! when u put it in gear and the torq forces the engine 2 move and when you have a failing motor mount the motor jolts because its not secure.....its coo tho thats a EASY fix bud......the one by the fire wall is gunna suck tho good luck
Old May 10, 2011 | 06:47 PM
Putt Putt's Avatar
Well since i am doing work on the motor i'll replace all of them. Do you know if new motor mounts come with hardware?
Old May 10, 2011 | 07:11 PM
alex14's Avatar
they do not. go to a junkyard to get the bolts.
Old May 10, 2011 | 08:35 PM
zach53's Avatar
yea they dont come with bolts but u should be able to use the bolts from the original mounts dude...
MidnightB16
May 14, 2009 11:53 AM
M.A.R.C.
Jul 9, 2005 08:57 AM
xSCTYGx
May 10, 2004 10:01 AM
GQ-Lude
Aug 13, 2002 11:06 AM
