99 civic si turn signal and hazard dont work help asap!!!!!
Old May 9, 2011 | 06:48 PM
99_EM1's Avatar
Default 99 civic si turn signal and hazard dont work help asap!!!!!
so i recently did a engine swap and i took it out for a test drive and flick the signal to turn....WTF...got home and checked the fuses (engine bay and under dash) everything was good..what you guys think it would be wrong? just spend all my money on the swap so don't plan on taking it to the shop..im sure they'll charge a arm and leg...any suggestions thanks...
Old May 9, 2011 | 06:49 PM
99_EM1's Avatar
Default Re: 99 civic si turn signal and hazard dont work help asap!!!!!
or if anyone knows where the relay is for this is? or a diagram of it would help and how to test if relay still works...thank guys
Old May 9, 2011 | 07:10 PM
Former User's Avatar
Did you forget to reconnect the plug at the rear of the hazard switch?
Old May 9, 2011 | 08:57 PM
that_boy_sammy's Avatar
Yeah thats what it sounds like. Top connector on the climate control.
Old May 9, 2011 | 10:16 PM
qpzm12's Avatar
there is a relay for the blinkers the one that makes the ticking sound when the turn signals are on, its under the dash its a black box kinda thing
Old May 10, 2011 | 08:19 AM
99_EM1's Avatar
under the dash...a black box...i need more info...
Old May 10, 2011 | 08:20 AM
99_EM1's Avatar
the hazard plug is plugged in...that the thing...
Old May 10, 2011 | 10:40 AM
qpzm12's Avatar
im not sure what its called. it went bad in my eg. i replaced it they started working again
its the relay that makes the blinking blink. its in your fuse box
Old May 10, 2011 | 01:50 PM
Test the hazard switch. Does it get voltage from both dash fuse 12 and hood fuse 53?
Paul 631
Dec 25, 2011 07:19 AM
ls19integra95
Feb 19, 2008 09:48 PM
Mr. Em1
Feb 5, 2008 12:41 PM
mattcivic
Jan 13, 2005 05:19 PM
jayputelis
Sep 25, 2004 09:00 PM
