Car sputters on startup
Old May 9, 2011 | 05:41 PM
crex23's Avatar
Default Car sputters on startup
I have a 88 hatch with a zc swap. About 2-3 weeks ago, I started the car up cold, and it was sputtering bad like it didn't want to run, and was really rich. After about a minute, it cleared up and ran fine. It still does this, when the motor is cold, or after its ran then cut off for 15-20 minutes and cools down a little. It doesn't do it if the motor is hot, and you turn the car off, and turn it right back on.
I've replaced the O2 sensor, plugs, and the dizzy is only 2 years old. No CEL codes either. It only sputters for about a minute, and I'll give it a little gas, then it will clear up and run fine. Its like its loading up on fuel or something.
Any ideas?
Old May 10, 2011 | 04:32 AM
crex23's Avatar
Default Re: Car sputters on startup
Forgot to mention, I replaced the valve cover gasket and spark plug tube seals since there was a little oil on the plugs.
Old May 10, 2011 | 05:45 AM
dadriver's Avatar
sounds like maybe a leaky injector
Old May 10, 2011 | 08:19 AM
19EF91's Avatar
take a screw driver put it to the injector and put ur ear to the screw driver and listen to each injector if one is a slow thud sound u have a messed up injector a good injector has a fast ticking sound
VTteg
Jun 1, 2008 06:31 PM
BB6racer
Jan 14, 2006 07:17 PM
hlee5363
Oct 6, 2005 07:20 AM
SOFLSOL
Oct 25, 2003 05:06 AM
