speedometer issue
Old May 9, 2011 | 11:18 AM
95civicproblems's Avatar
Default speedometer issue
My speedometer didn't work when I got the car. It sometimes stays at zero, sometimes jumps around erratically, and sometimes works. Just recently I had a brake issue where something was sticking and I had it fixed. This seemed to make my speedometer work a lot more often than it used to. It now works about 70% of the time where as before it worked about 10% of the time. I don't see how those things are related.. maybe it was a fluke. Idk. But i want it fixed. I had the speedo sensor that goes in the tranny behind the engine block replace twice with no real noticable difference. Check engine light never came on.
Thanks in advance.
Car: 1995 Honda Civic LX
Old May 9, 2011 | 12:49 PM
Former User's Avatar
Default Re: speedometer issue
Is the VSS CEL code thrown?
Old May 9, 2011 | 12:56 PM
Sorry I forgot to mention there is no check engine light on. It never came on. Although the ABS light is on. But Idk if that is related.
Old May 9, 2011 | 12:57 PM
Does the CEL work? Click on the CEL sticky.
Old May 9, 2011 | 01:13 PM
Good point. I never thought about that. Will check. Thanks so much.
Old May 16, 2011 | 07:59 AM
The CEL does work. But does not stay on. Now what.
Old May 18, 2011 | 08:09 AM
Bump. Please help :/
Old May 18, 2011 | 08:17 AM
Redcivic888's Avatar
Try swap out the speedometer from any eg
Old May 18, 2011 | 08:20 AM
Had the same problem replaced the vss not help so replace the speedometer from another eg now it's working fine
Old May 18, 2011 | 10:48 AM
Alright I'll hit up the junk yard, grab an EG speedometer, replace it, and see if that works. Hope I don't grab a bad one! (:
Old Jul 23, 2011 | 03:32 PM
justinsbg's Avatar
If your VSS is not the culprit, the problem is most likely your Speedometer PC board. Usually with VSS problems the speedo will either work or it won't. Your PC board can be fixed. I can repair it for you with quick turn around time and good pricing. I'm a Honda/Acura tech in NC full time and repair electronics in my spare time. Let me know if I can help with diagnosis and/or repair.
Old Jul 23, 2011 | 06:23 PM
virgineg6's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-civic-speedometer-fix-2792878/
Give this a try, if this dont work i would suggest replacing the cluster
924drb20
Aug 19, 2010 07:59 PM
superstock2
Sep 15, 2006 01:44 PM
bma1818
Apr 15, 2006 11:36 AM
Chicano
May 8, 2005 08:43 PM
Hatchy-Ownzjo0
May 23, 2002 08:31 AM
