choppy throttle, idle stalls - fuel pump?
Old May 9, 2011 | 04:00 AM
bigbangmtl's Avatar
Icon3 choppy throttle, idle stalls - fuel pump?
Car: 1999 Honda Civic CX Hatchback
Symptoms:
-choppy throttle (random episodes, works fine sometimes)
-idle stalls (the car randomly stalls in traffic sometimes)
-long starts (take a few extra cranks to start than originally)
Recent changes to car:
-1000w rms amp sound system (4 weeks ago)
-distributor changed (2 weeks ago)
-fuel filter changed (1 week ago)
Any advice would help. I have a 16 hrs trip planned in 2 weeks and need a running car. Thanks.
Old May 9, 2011 | 06:37 AM
foo fighters's Avatar
Default Re: choppy throttle, idle stalls - fuel pump?
Check your main relay. Is your fuel pump priming 10 times in a row? Do you have intermintant primes??
Old May 9, 2011 | 08:53 AM
bigbangmtl's Avatar
When I turn the key to ignition, I hear the relay click, then the fuel pump priming for 2 seconds and then the relay clicks again.
That's it. Any other tests I should do?
Old May 10, 2011 | 05:31 AM
bigbangmtl's Avatar
Problem solved.
The culprit was an old remote start installed by a previous owner that was cutting into the ignition wire. Remove it and repatched the wiring and it works great now.
Thanks for the feedback foo fighter.
Old May 10, 2011 | 07:39 AM
SWEET!! HONDA POWER!
alanartwww
Sep 17, 2013 06:14 PM
Broke_not_built
Aug 22, 2011 10:40 AM
TattoonistInk
Aug 17, 2008 10:56 AM
i_VTEC
Feb 25, 2008 01:55 PM
ZedEx
Jul 1, 2005 01:41 PM
