FS:P28w/Neptune RTP, ID 1000s, Inline Pro turbo manifold, AEM/MSD Ignition
David Heeter
Valdosta, Ga 31605
229-251-2676
text, call, or pm
I am in the middle of doing a K-swap so all my B-series parts need to go
Inline pro SS mani, Tapped for T3 or T4, comes with 2 bolt fange for wastegate $425 shipped
31 x 4 Inter cooler with 2.5 inch Inter cooler Piping, has HKS Bov Flange $225 shipped or $175 picked up
3 inch,4 bolt used passenger side downpipe $60 shipped
New, 3 inch 4 bolt downpipes, passensger side style,(works with logs and ramhorns, $110 shipped
New, 2.5 inch passenger side downpipe, no flanges, brand new $75 shipped
Ignition system - $475 shipped
AEM Twin Fire ignition box, removes factory ignitor which tends to fail on high power aps, $290 shipped
GSR Distributor with MSD Cap and Rotor, MSD SS Coil $150 shipped
MSD 8.5mm Wires $60 shipped
Motor 84.5mm Golden Eagle sleeved Block,Damaged
The Bad, Dropped a valve that took out number one. Local shop said it can be bored to 86mm but I recommended sending it into Golden eagle or another sleeving company (Darton, ERL, etc) to get re-sleeved
The Good, GSR Block (saves core charge), GSR Crank, Main Caps with ARP studs, Girdle with ARP Studs, GE oil squirters, Crower H beam rods. Send it in and get it resleeved, buy a set of pistons and bearings and you have a new built bottom end. $600 obo you pick up or pay to ship
Will sell Block with Crank, caps, girdle, squirters and APR studs for $400 picked up
Crower GSR H beams rods,used for 3500 miles for $200 shipped
Misc items
Neptune RTP Demon inside xenocron converted P28 with pwm/boost by gear, will transfer license $425 shipped firm
ID 1000 Injectors, 2 months old, comes with obd 1 plug n play clips SOLD
Blox Billet 70mm TB, includes blox tps and hondata gasket $160 shipped
Aem B-series Fuel Rail, Black $70 Shipped
Omni 4 bar map sensor $70 Shipped
EK Fog Lit kit complete and new $35 shipped
ITR Throttle Cable and bracket $20 shipped
92-95 Civic 3 gauge pillar pod $35 shipped
Blox b series cam seal, new $20 shipped
GSR Cams $60 pending
GSR repainted wrinkle black Valve cover $55 shipped
Stock/Swap parts(b-series)
B series, GSR Alternator (1 month old) $70 shipped
92-95 obd 1 Vtec Engine Harness $110 shipped
B-series Vtec solenoid $25 shipped
B- Series GSR IACV $25 Shipped
Also have every sensor or B-series swap part available from the long block, Pm me with a request
Valdosta, Ga 31605
229-251-2676
text, call, or pm
Misc items
Photobucket link for pics
http://s3.photobucket.com/albums/y73/heetstroke/
$425 for neptune and ecu with boost by gear and $425 inline pro ss t3/t4 turbo manifold bump.
Lets move these items
heetstroke
May 17, 2011 11:01 PM
