Car running a little to hot!
Old May 8, 2011 | 06:07 PM
sgnlab's Avatar
Default Car running a little to hot!
Hey guys.
I have a car with darton sleeves, gt35r with water lines setup.
I am having an issue the car is running a little to hot.
1st thing I Changed was the thermostat.
When I turn the car on everything is ok and if it sits and idles to long it will get right up to 200 and will climb but I just shut it off.
I changed the radiator fan to a 2150cfm cooling fan and it seems to work but it comes on and off way to often when sitting in traffic.
I set up the s300 to have the fan come on @ 188 and if the car sits in traffic the can comes on and shuts off very often. During regular driving the fan stays off and the car is @ 185.
The radiator is a shitty ebay one but I have done many cars that have ran this same radiator.
What else have you guys tried and what do you guys recomend for a radiator?
Old May 8, 2011 | 06:21 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Car running a little to hot!
My friend had the same problem and he removed his thermostat and the issue was resolved. I forgot to add he has a Darton sleeved block with a 30R and civic half rad.
Old May 8, 2011 | 06:22 PM
TURBOINTEGRA750's Avatar
I dont run a thermostat in my integra an i only have a civic radiator
Old May 8, 2011 | 06:28 PM
sgnlab's Avatar
So ditch the thermostat. I will try this tomorrow.
Old May 8, 2011 | 06:34 PM
hello1320's Avatar
Don't take it completely out
Old May 8, 2011 | 06:36 PM
sgnlab's Avatar
Explain!
Old May 8, 2011 | 06:37 PM
EmminoDaGreat's Avatar
I have seen some ebay radiators have very thin flue's which cause some overheating issues at times.
Old May 8, 2011 | 06:40 PM
sgnlab's Avatar
I might have to get rid of this radiator.
Old May 8, 2011 | 06:43 PM
BADGUYNY's Avatar
if you do keep the thermostat in drill holes in it
Old May 8, 2011 | 06:45 PM
sgnlab's Avatar
This was the type of thermostat that was in there to begin with same results. Had about 10 small holes drilled into it. Same exact results.
Old May 9, 2011 | 07:06 AM
lsvtecracer's Avatar
I usually just cut the center section of the thermostat and leaving the rest of the housing it to prevent leak. I do it for all my customer's car and no problem with overheating.
Steve
Old May 9, 2011 | 10:05 AM
zakura R's Avatar
Icon6 Re: Car running a little to hot!
Hey steven check that ur fan is not wire up reverse ?? And check ur water pump
Old May 9, 2011 | 10:18 AM
Garage 808 Hatch's Avatar
The fan is supposed to come on it traffic, as you are moving too slow to move air through the radiator to cool the water. The fan moves the air for you. You'd hate to drive an RDX, stock the fans come on all the time. Have you tried propping the back of the hood up to help the hot air escape the bay? Is the DP really close to the radiator? Is it coated or wrapped? coating the DP/mani/and exhaust housing helps a lot also
Old May 9, 2011 | 11:56 AM
fast is fun's Avatar
do you have fan shroud ?
Old May 9, 2011 | 12:17 PM
jnv255's Avatar
Mine got hot like that until I noticed the fan was blowing the wrong way...Reversed it and it's fine now.
Old May 9, 2011 | 05:02 PM
blackeg's Avatar
i have my fan come on at 175-180 during the real hot weather.
i was also running hot last year. i propped the hood up in the back and it helped a little bit. this year i put 4 decent size holes in the tstat and heatwrapped the manifold and downpipe. its not warm enough here though to see if it worked yet
Old May 9, 2011 | 05:11 PM
NY GsR's Avatar
take the thermostat out
Old May 9, 2011 | 05:50 PM
Topdawgg's Avatar
Steve
is this a common thing to do in street cars as well as track cars? or mostly track cars?
Old May 9, 2011 | 07:35 PM
Divers's Avatar
Get an electric waterpump and never look back.
Old May 9, 2011 | 08:23 PM
BMo Tuning's Avatar
STAR
My last daily driven turbo integra used a ball bearing, water cooled turbo, I only had over heating (220F) issues when I ran a cheap *** cx racing radiator. I tried everything with that pos in there, i ran straight water with water wetter, no thermostat, nothing worked to keep it in the 195 range.
It ran "normal" once i switched out to a better radiator with more volume.
Old May 9, 2011 | 09:03 PM
I do this to all the turbo car that we build. It help on the street car because we only see temps at around 180-185 when cruising and right at 195-200 after a full run.
Steve
Turbo-charged's Avatar
get really really drunk and pee in the radiator
Old May 9, 2011 | 09:29 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
exacto! I have one for sale if you want it , other wise get a stewart EWP. Maxx and Tony have them and they are way way cool at the end of the track, (no pun)
Steve
yep what i did. SInce I did that and ran the EWP on a exo front end, I havent had any over heating problems. And I live the Texas
Old May 9, 2011 | 09:50 PM
edstone83's Avatar
Does anyone have pictures of an intalled/mounted electric water pump? I am looking for ideas on how I should mount mine.
Old May 9, 2011 | 10:01 PM
newschool's Avatar
this wouldn't happen to be on some **** k-series would it?
