Which exhaust/headers to buy
Old May 8, 2011 | 12:59 AM
Grimmage's Avatar
Default Which exhaust/headers to buy
I have a 95' Integra GSR with a 2000 GSR motor and I was wondering if I buy the exhaust for the 95' body and headers for the 00' motor, or both for the 95' model or both for the 00' model.
Old May 8, 2011 | 06:39 AM
db8gsr_teg's Avatar
Default Re: Which exhaust/headers to buy
depends on which cat you using.
Old May 8, 2011 | 09:55 AM
da_all_day's Avatar
even with the size of the cat, you can always get the headers cut to fit or get a "high flow cat" and get THAT cut to fit so you can avoid having to hack your headers...
Old May 8, 2011 | 10:17 AM
uptownspeedstar's Avatar
94-01 is the same.
Old May 8, 2011 | 10:43 AM
94VTEC2TONE's Avatar
how much money do you have? such an open question. goals for the car?
Old May 8, 2011 | 01:00 PM
turboskratch's Avatar
If it's a 2000 GSR engine, did the header/cat/exhaust come with the engine? because if so, you need a 00-01 exhaust/header. If the 95 piping/header/cat is the same, then you need a 94-99 GSR header, and a 94-99 GSR exhaust. The header/cat length is shorter on the 94-99 GSRs, so the exhaust midpipe is extended a little bit.
Old May 8, 2011 | 02:23 PM
Grimmage's Avatar
Well right now it's just stock headers to a straight pipe. I was wanting to put aftermarket headers on it a high-flow cat to an apexi exhaust.
Old May 8, 2011 | 03:18 PM
hytech replicas popular becuz you get a test pipe with it usually, or smsp how much do you want to spend really
Old May 9, 2011 | 06:53 PM
pdevilk's Avatar
DC or greddy
Old May 9, 2011 | 07:23 PM
dragon909boi's Avatar
goals for thE car? purpose of it? too vague ... other than that i would go what 9+4vteczone zone said hytech replicas
Old May 9, 2011 | 09:39 PM
Jimmy's Avatar
Global Moderator
Run a quick search of ''header'' in the all motor forum, you will be surprised at the results...
https://honda-tech.com/search.php
Search topic titles only
Kr4nG
May 24, 2007 01:59 PM
shhh151
Jul 22, 2004 01:31 PM
AznInvasion
Jan 15, 2004 04:58 PM
Hybrid2Be
Dec 18, 2003 07:33 PM
BlackAC99
Nov 14, 2002 09:00 AM
