Mid-Atlantic (Sales) VA, DC, and MD
FS: B18c Stock Sleeved Turbo Short Block.
Old May 7, 2011 | 08:05 PM
A13sechatch's Avatar
Default FS: B18c Stock Sleeved Turbo Short Block.
Name-Bernie
Loc-Baltimore
Contact-IM
Price-Best Offer
__________________________________________
Up for sale is my stock sleeved B18C turbo short block, it has Wiseco piston and brand new rings and big bolt forged rods and all brand new ACL race bearings. i had this setup in another block but cracked a sleeve due to a fulty timming belt, the rotating assembly was fine so i changed the bearings and piston rings and put it all into another block. The setup went 10.91 @ 136MPH on pump gas. i haven't even put the head on yet its ready for a new owner. looking for best offer.
Old May 7, 2011 | 10:10 PM
los02's Avatar
Default Re: FS: B18c Stock Sleeved Turbo Short Block.
Can you give a ball park of what you looking for? What brand are the rods? Did you have the rotating assembly checked at a machine shop to make sure that nothing is bent? Any machine work done to the block prior to having the stuff above installed? I'm interested. But don't want to lowball you without knowing more about it. Thanks.
Old May 7, 2011 | 11:26 PM
1500 is the asking price. Galaxy rods i never heard of them but i took them to my machinist and he checked them out and said they were fine, i made over 500hp on them and mis shifted a few times and they held up just fine. its pretty much a stock block with pistons and rods type-r crank. new oil and water pump. head studs and brand new cometic head gasket..the timming belt didnt break it sliped at the end of my pass causing the motor to detonate and cracked the sleeve, The cyl. immediately filled with coolant shutting the motor off the car was towed to the trailer and disassembled at the shop.
Old May 10, 2011 | 03:40 PM
bump
Old May 15, 2011 | 08:30 PM
ttt
TrackSpeedRacing
Northern California (Sales)
26
Jun 4, 2014 05:11 PM
2 0 3
Northeast (Sales)
10
Mar 1, 2011 03:32 AM
promotor
Dec 5, 2010 04:49 PM
kawaii05
Jan 25, 2006 07:15 AM
94delsol
Aug 25, 2004 08:33 PM
