Suspension & Brakes Theory, alignment, spring rates....
Progress CS-II ride height issue
Old May 7, 2011 | 04:23 PM
grumblemarc's Avatar
The Grumpiest
Default Progress CS-II ride height issue
I rarely post up with issues so here we go.
Are they supposed to slam you like this? I was not expecting this kind of drop at all. I installed these on the fronts only and I was hoping to keep the 1/2" gap I had prior to installing these. The 18's I had on there were tucking tire so I thought If I swapped the 16's off of the wife's hatch that I would get some clearance back but that was only a quarter of an inch.
The exhaust piping is only 2 1/2 inches off of the ground. Also I'm getting rubbing on the splash shield on the drivers side only, which appears to be about a half an inch lower than the passenger side. Mind you I have these dialed up all the way to the top of the perch.
The ride quality however is SWEEET!. Not too happy about the drop. So do I have suspension issues that I need to address or is this it?
Old May 7, 2011 | 05:05 PM
The Grumpiest
Default Re: Progress CS-II ride height issue
Okay. Thinking about this a little further. There's about an inch and a half of the shock that slides into the fork. Would there be any issues in trying to reclaim some height by setting the fork at a lower point on the strut?
Old May 7, 2011 | 10:51 PM
98civdx's Avatar
Master Detailer
The car is all the way up and still to low?
Hmm, I have only heard of this when using H&R ultra lows. lol
Which car is the car in question?
I am lower, and have 0 issues. Neither of those cars is slammed.
Old May 8, 2011 | 02:58 AM
The Grumpiest
The blue beater is the car in question. And it's slammed to me. Not a lot of ground clearance and having to use a low profile jack constitutes slammed in my book.
Old May 8, 2011 | 08:38 AM
The Grumpiest
Tried my "fix". Looks normal now. Taking it out for a test drive in a minute.
Old May 8, 2011 | 10:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The little notch going around the bottom of the front dampers should align with the pinch bolt on the forks. I would not trust the dampers not being fully seated in the fork. It will try to slip down to seat itself. Mine always does when I don't get my forks fully seated when putting the suspension back on. When I first drive it, it will make a loud metallic TWANGGG sound as the forks seat themselves against the brake line brackets on my Koni shocks.
Old May 8, 2011 | 11:03 AM
Tyson's Avatar
its a little refreshing to hear someone complaining they want MORE ride height. heh.
Old May 8, 2011 | 11:31 AM
94VTEC2TONE's Avatar
i think the ride height looks great man, thats not slammed at all. and i dont think i would try to even try to not fully seat the shock, theres probably a reason it sits in the fork the way it does
Old May 8, 2011 | 03:28 PM
The Grumpiest
Okay! Noob mistake. Somehow between the mockup I did a few weeks ago and the actual installation the springs got swapped around and the 250s are what I just spent my Saturday morning installing. I wouldn't put it past one of the family members to have been monkeying around with my parts. It wouldn't be the first time.
That's why they are sitting so low I imagine and why I was wondering how Progress considered this a 1" drop.
Don't have the time to swap them back around tonight but at least I have some piece of mind knowing there isn't a defect with the car or the CS-IIs.
Old May 8, 2011 | 04:50 PM
Libertariat's Avatar
Ek Forever y0!
Good find. pain in the *** to have to swap them after all that work.
I was glad I got 350/350, lol, i didn't have to decipher which one was which. As they aren't marked.
And they do ride amazingly well. I'm very happy with mine. Glad to see one of us regular posters got them also. Now you and I can both honestly say there is no reason to get skunk2 suspension products. LOL.
Progress < Koni/GC < AMR
End of story.
Old May 8, 2011 | 09:10 PM
r_Senik's Avatar
wow, that sucked, yea glad i got the 350/350 too! hands down the best bang for your bucks suspension here.
Old May 9, 2011 | 10:02 AM
area522010's Avatar
So you cant go lower than 1"?. Not looking for a slammed look but wanna go atleast 2" buying mines today
Old May 9, 2011 | 10:19 AM
Ek Forever y0!
You can lower it however much you want to. Progress doesn't recommend going lower than 2.5" front and rear.
Old May 9, 2011 | 06:00 PM
The Grumpiest
Progress states a 1-3" drop.
Old May 14, 2011 | 06:49 AM
The Grumpiest
Swapped out the 250s for the 350 and the ride quality is even better. Still about the same height as before but I'm not too concerned about bottoming out like I was before. Heading to a shop right now to get the frozen rear LCA bolts broken loose so I can get the rears, swaybar and LCA's installed.
Old May 14, 2011 | 07:48 AM
Ek Forever y0!
Man, I got so lucky. I had 0 issues with any bolts on the suspension when I installed mine.
Old May 14, 2011 | 12:11 PM
sc34dc4's Avatar
I have the 350/350 on my dc and love it.
Old May 14, 2011 | 01:24 PM
efvader's Avatar
Put the rears in and post more pictures.
Old May 18, 2011 | 08:29 PM
oneoffaccord's Avatar
so its seems like everyone likes the 350/350 rates. i should be getting me a set next week
Old May 19, 2011 | 02:19 AM
Ek Forever y0!
If I had it to do over again I wish I'd gotten 500F/350R
Without a front swaybar at least the front rates seem soft. Being that the engine is under those rates it makes sense, but without having rear rates at least close to that 500 you might create a lot of understeer. Not too sure.
Old May 21, 2011 | 06:07 PM
93Eh6pWr's Avatar
Every time I read about the CS2's, i want them more and more.
Are they still out of stock?
Old May 21, 2011 | 08:33 PM
Ek Forever y0!
https://honda-tech.com/forums/showth...692801&page=50
Looks like June 3rd
Old May 25, 2011 | 02:30 AM
PosDAninja's Avatar
If your still concerned about bottoming out put the 18" back on, the gap isnt so much what causes bottoming its the chasis height. With the larger wheels the chasis is gonna be higher.
Old May 25, 2011 | 02:40 AM
The Grumpiest
Been taken care of. If you check teh problem was with the wrong springs being installed in the front.
Old May 25, 2011 | 07:45 AM
Mr. Spade's Avatar
no
this.
I have 350/650. 350 isn't stiff enough; might raise it a bit cause I don't want to spend more on getting new crap.
