1990 da/ 95 ls swap. wont start wont crank. cant hear the fuel pump.
ok so i recently bought a 1990 integra shell. no motor no tranny. so i bought a 95 integra motor and a b16 cable tranny. motor is in the car used obd0 wiring harness plugged everything in. go to start the car and the cluster lights turn on but no crank. i dont hear the fuel pump. no sounds at all. have no idea what to start checking.. any ideas? what can i check?
Check the main relay ground. On the dc2 it is on the thermostat housing I'm not sure if that is.where it is on your ra or not. Also check and make sure you have a main relay. Check all fuses under hood and dash. Make sure your pgmfi fuse is good.
where is the pgmfi fuse??? where is the main relay?? i think i checked and i dont have a fuel pump relay .. does that make it not crank???
OK lets start off by saying that your 90 integra is OBD0 while the 95 motor is OBD1. What kind of distributor are you using? What kind of starter, Alternator? did you change anything out from the motor to convert it to obd0. The car will not start if you Shi* is all miss matched in OBD.
ok i have a 1990 acura integra. 1990 b16 tranny 95 block and head.. obd0 intake manifold. obd0 starter and alternator. obd0 wiring harness
check if u even got a main relay n fuel pump relay ..
under dash driver side (lil brown box n black box)
then check if ur starter is connected
both check out ur car should crank
no fuel pump relay car will still crank but wont start
whasian
11
Nov 7, 2013 02:53 AM
