Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
A/C conversion kit for a 06 civic DX??
Old May 6, 2011 | 08:51 AM
amonslow's Avatar
Default A/C conversion kit for a 06 civic DX??
Hey all. Im a new member now. i am not new to this site. I have found a lot of useful info from here just never as a posting member.
Okay, now to my question. My girlfriend has a 06 civic dx. She wants an A/C unit on it. I know they have conversion kits. The cheapest I have found is $1,060. We called honda and they quoted $800 to install. Is there any way to maybe make our own kit and buy the parts independently to make a kit? There has to be a way save a little money i would think. Could I just buy like the Compressor and lines off ebay and maybe get the necessary parts at a junk yard? Thanks for your help guys.
Old May 10, 2011 | 02:31 PM
amonslow's Avatar
Default Re: A/C conversion kit for a 06 civic DX??
nobody can reply? anyone please!!
Old May 10, 2011 | 02:49 PM
m_shake's Avatar
Im sure you could source used/ebay parts but have fun making sure you get every part needed...
Old May 14, 2011 | 06:15 PM
Charlies Auto's Avatar
Hi.
If vehicle comes without A/C, you need following parts.(probably you know already)
-A/C compressor(with thermo switch and clutch assembly and field coil installed)
-New belt(serpentine belt)
-High side line from compressor to condenser (receiver/dryer installed)
-high side line from condenser to mid connector.
-High side line from mid to evap.
-EVAP unit
-Temp sensor on EVAP unit
-TXV(thermo expansion valve) valve(usually comes with EVAP)
-Low side line from EVAP to mid connector
-Low side line from mid to compressor
-metal grommet to holds line.
-0.45kgs of R-134A gas.
If you buy all stuff individually, it will be cost more than C$2,000.
Just call around dealer , find better price.It will be much cheaper.
Also you have to remember , you can not rely on the parts from junk yard .
If accident happens, where was get damaged first? front parts. Condenser and compressor.
Hope you will get proper installation/
From Canada ON Kitchener
MilesToEmpty
Jan 23, 2015 06:22 PM
93egSLEEPER
32
Jun 26, 2013 02:46 AM
realred96
Classic Hondas
Aug 13, 2011 02:29 PM
MegaBleeder
Feb 29, 2008 11:12 AM
loudassVTEC
Dec 13, 2005 05:16 PM
