my smanager is buggin out with the floating point division by zero in the display
Old May 5, 2011 | 11:55 PM
trunkluv's Avatar
Default my smanager is buggin out with the floating point division by zero in the display
i was setting up my display window and clicked on a/f gauge to setup and this warning window came up saying floating point division by zero, but the menu pops up so repeatedly that its impossible to get out of the display window and i have to hold my finger on enter or esc to delete all the mini warning windows but they keep popping up now matter how much or fast i delete them. now i cant even open the display window with out it freaking out. i tried deleting every hondata file and reloading the program but nothing works. what do i do? i am using an hp if that helps at all
Old May 6, 2011 | 05:30 AM
mtber's Avatar
Default Re: my smanager is buggin out with the floating point division by zero in the display
Your answer can likely be found much quicker on the hondata support forums:
http://www.hondata.com/forum/index.php
Old May 6, 2011 | 05:39 PM
trunkluv's Avatar
already a member and no luck
Old May 6, 2011 | 05:57 PM
mtber's Avatar
Did you make a thread? I didn't see it.
mtber's Avatar
Read this, maybe it will help: http://www.hondata.com/forum/viewtopic.php?f=19&t=12232
Old May 6, 2011 | 10:46 PM
trunkluv's Avatar
Originally Posted by mtber
thanks i found like 4 threads and both ended up in dead ends. seems like i just need to delete the display template but i cant find it in my program files
Old May 8, 2011 | 10:01 PM
mtber's Avatar
If that doesn't work try emailing hondata's support team via support (a-t) hondata.com
Old May 10, 2011 | 11:02 AM
Importracer_001's Avatar
I think that I might have had this issue before, just end your hondata session in your task manager (ctrl-alt-del-task mgr) and re-open the s300 application.
Old May 11, 2011 | 11:50 AM
iskate2's Avatar
I had this problem recently. Make sure you go to your control panel and uninstall it. then reinstall it.
Dont try to change the display template while you're datalogging, that caused it for me.
bsiple
Audio / Security / Video
Jun 8, 2005 04:38 PM
Will_H
Apr 25, 2005 12:04 PM
Jeff92NY
Jun 26, 2003 05:39 PM
