How can I tell if it is a H22a JDM motor?
I am buying one locally and it's an automatic. I am thinking about just buying the motor without the tranny. If so, can it be convert to manual tranny. What do I need (flywheel???). Please help. Thank you.
It could be an auto from a 5th Gen...
Make sure it just says "H22A".. Not "H22A4"
[Modified by satan_srv, 10:06 PM 9/29/2002]
for it to be converted to a manuel, you're need clutch, flywheel, ECU, axles, slave and master cylinder, tranny, shifter cables, gauge cluster, and another pedal. Maybe theres something else, but those are your main parts
well the engine i think should say h22a not h22a1 or h22a4 and it should have an internal coil (not sure what the 5th gen had though)
i think his car is manual...to convert the engine to manual all you would need is a flywheel
And the flyhwheel bolts. You cant reuse the flexplate bolts.
tim.simpson
Dec 25, 2001 10:36 AM
