all motor B18c build advice?
Old May 5, 2011 | 05:19 PM
CRX-boy's Avatar
Icon6 all motor B18c build advice?
I have everything but the pistons but im getting some b20b/z JE 11.1:1 pistons tomorrow.I am just wanting to here some input on what else I [NEED] to do to make it run right or if it will run fine how I am building it.I plan on upgrading to a gsr head and upgrading cams,valve springs,ect.I have a b18c block bored&sleeved 84mm,stock ls crank,eagle rods,eagle block guard,ls head stock,all stock ls inj,fuel rail,intake.It does have a 4into1 header with thermal research catback exh.will it run,will it run good.try and guess my hp?I will prob get 270cc inj.
Old May 5, 2011 | 06:49 PM
Mr. EG's Avatar
Default Re: all motor B18c build advice?
In before the lock.
*On a side note learn how to type/ speak in context*
Old May 5, 2011 | 08:15 PM
C_Rock77's Avatar
Jumping in the pool!
I mean...I read these posts and ask myself: "Aren't the FAQs still there? Did they hide them? Are the All Motor Dyno threads all gone?"
Then, I look and see. "Nope, they're still there where they're supposed to be."
Also, if you can't compose an intelligible sentence, don't post.
Old May 5, 2011 | 08:21 PM
samhonda95's Avatar
how can it be sleeved and have a block gaurd too???
Old May 5, 2011 | 08:37 PM
SoHc94's Avatar
u can resleeve a cylinder. it doesnt necessarilly close the deck off. some sleeves just replace the existing worn/bored out sleeve. with a fresh stock bore sleeve.
Old May 5, 2011 | 08:48 PM
93egSLEEPER's Avatar
Dont make fun of the guy when your not sure youself. You can sleeve a block and run a block guard....its pretty common actually.
Old May 10, 2011 | 07:27 PM
CRX-boy's Avatar
I don't have alot of time to sit around on the computer all day.So I'm just wondering if It can withstand a turbo with the 11.5:1 pistons and it still hold up being bored to 84mm.I have heard of the sleeves spliting just wondering if someone else has done the same build and if it ran strong.and yes it has been bored and sleeved to 84mm with an golden eagle blockguard.I am wondering which head would be the best to use for this set up.thanks for the advice
Old May 10, 2011 | 07:30 PM
CRX-boy's Avatar
Originally Posted by Mr. EG
In before the lock.
good advice dick
Old May 10, 2011 | 07:33 PM
CRX-boy's Avatar
Icon6 Re: all motor B18c build advice?
[quote=C_Rock77;45212457]Jumping in the pool!
(you have too much timeee I am a mechanic not a computer freak
Old May 10, 2011 | 08:49 PM
UncleD's Avatar
You don't need to be a "computer freak" to read.
Old May 11, 2011 | 04:45 AM
Libertariat's Avatar
Ek Forever y0!
I read it 4 times and I'm still not sure what he's saying.
Old May 11, 2011 | 06:10 AM
4piston's Avatar
Run more compression.
Old May 11, 2011 | 07:49 AM
C_Rock77's Avatar
I figured a MECHANIC that lives in TN would know how to speak ENGLISH and how to compose a halfway intelligible sentence.
Good luck getting your question answered with that attitude...
xkjnboix
Mar 14, 2016 06:16 AM
91Honda_gsr
Engine Machining & Assembly
Dec 17, 2015 02:21 PM
freakie
May 14, 2004 12:25 AM
oMek
Apr 11, 2004 01:24 PM
88hondahatch
10
Jun 17, 2003 03:32 PM
