Not sure what kind of gun or pressure
Old May 5, 2011 | 03:38 PM
Draiga1988's Avatar
Default Not sure what kind of gun or pressure
Hi i am about to do my first paint job with a air paint gun. I am not to sure on what the brand is. All i know is that the paint container is bottom mounted an is infront of the handle. when I can get a pic up I was wanting to know if any body knew what the psi should be. I am being told to use 30to 35 psi for the base coat then for the top coat use 30 then for the clear use 25 but that is with out them seeing the gun. Any information given will be greatly appreciated thank you for future info.
Old May 5, 2011 | 04:00 PM
Hawkze_2.3's Avatar
Default Re: Not sure what kind of gun or pressure
You want to paint a car with one of these?
Good luck....you will be much better off with a good gravity feed gun instead.
Old May 5, 2011 | 07:05 PM
Draiga1988's Avatar
The gun is a campbell hausfeld from what im reading it is a good gun. But i have yet to find the psi usage lol.
Old May 5, 2011 | 07:51 PM
Jerms's Avatar
You don't need a gravity feed gun, its all in what you feel comfortable with...
Old May 5, 2011 | 07:52 PM
Draiga1988's Avatar
This is the gun that i have its a Campbell Hausfeld.
Old May 5, 2011 | 08:50 PM
Hawkze_2.3's Avatar
It will work if you have the skill, but the tank below the nozzle makes it awkward in some positions. You will be more likely to get uneven coverage with those types of guns on a car.
Also, you need to find out the CFM usage to make sure your compressor can keep up.
Old May 6, 2011 | 02:20 PM
rxbahamut's Avatar
Get a Eastwood gun I bought one they are great. They are almost a LVLP gun so they will not be too bad with over spray. The best part is they will run on many compressors. I have a 25 gallon and I think you might can use a lower one maybe even a 15 or 10 gallon.
Old May 6, 2011 | 08:08 PM
Draiga1988's Avatar
everything went perfect with this gun no issues i did have some uneveness at the start but i adjusted it a bit an got it perfect i will post the results as soon as i can get them to my pc lol.
McCurry
Apr 13, 2006 06:51 AM
torqueless
Jun 5, 2005 09:31 PM
HomeBuilt
Dec 25, 2004 11:52 AM
Tyree
Dec 23, 2004 10:59 AM
civickid77
Oct 9, 2002 11:50 PM
