H Series Build (Few Questions)
Old May 5, 2011 | 01:54 PM
SlipGear's Avatar
Default H Series Build (Few Questions)
Car is an '98 EK hatch (base model manual everything), car is obd1 converted and will be tuned on a chipped p28
Engine:
H22 (its jdm if that matters)
Short Ram Intake
Head:
Crower Stage 2 Cams, Retainers, springs
Slight port/polish
Trans:
M2S4
Exedy Stage 4 Clutch
Gator Stg 2 axles
Suspension:
Omni Full Coil Overs
Full Race Traction Bar
Camber Kits
LCA
BFG Radials
Exhaust:
RMF Drag Header
2.5" Piping
Misc:
MSD SC Ignition
FPR
Short Ram
CF Hood
My Questions:
What would be the redline for the build (cams are good for 8500, but idk about the rods)?
I'm looking to dip into the 12's (any suggestions if i'm not already there)?
Any items you would recommend changing?
Any weight reduction suggestions (not to drastic)?
Thanks in Advance
Old May 5, 2011 | 05:39 PM
teefunk01's Avatar
Default Re: H Series Build (Few Questions)
Ideal redline would be when you actually dyno and see where your power curve ends
Check out h22squad.com
Old May 5, 2011 | 09:50 PM
H2b-eghatch's Avatar
use b series tranny
Old May 5, 2011 | 10:23 PM
Krut's Avatar
Personally this is what I would go for:
Pro1s
I would change to 3" exhaust
B trans
Slicks will help you reach your goal much better than drag radials
Everything else looks good
Old May 6, 2011 | 06:32 AM
H2BJON's Avatar
If you end up going h2b, I would recomend the qsd kit, I'm on my 2nd kit!
Old May 8, 2011 | 01:14 PM
Yamabu's Avatar
Same question, zero experience with Hondas.. converting F23A1 (Vtec) engine auto tranny to M2S4 manual... but, also have MT from another F23A1. From what I've read, sounds like ratios on M2S4 are tighter, more fun...but is 5th too low in the M2S4 for allot of highway driving? too much conflicting info... whatcha think...
Old May 8, 2011 | 10:32 PM
FTW, what was wrong with ur first kit?
Old May 9, 2011 | 05:38 AM
Libertariat's Avatar
Ek Forever y0!
Probably sold the car or wanted one for his daily, lol.
Old May 9, 2011 | 02:20 PM
Yamabu's Avatar
got the M2S4 months ago after auto tranny died. needed all of the other parts... linksages, lines, shaft, starter--- local junkyard had the same car sold me tranny and everything I needed for $500, so I have two...
Old May 9, 2011 | 04:49 PM
walker456's Avatar
op read this see if it appeals to you
https://honda-tech.com/forums/showth...light=g23+vtec
SCsol
Nov 27, 2016 06:38 PM
95dragon
Jan 31, 2010 05:47 AM
nogi
Oct 9, 2007 02:20 AM
hipity_hopity_mt
Feb 28, 2005 04:48 PM
