94 HB Front Speakers Help
Old May 4, 2011 | 04:37 PM
EG FTW's Avatar
Default 94 HB Front Speakers Help
alright i got a 94 civic HB and the front speakers i got JL Audio C2-525x they dont fit properly beucase of the notorious shallow brackets...so my question is to get my speakers to fit properly in the stock locations what should i use as a spacer to fix the depth issue besides using washers and longer screws? any help would be appreciated thanks.
Old May 4, 2011 | 05:45 PM
0c00l's Avatar
Default Re: 94 HB Front Speakers Help
You can make some using a jigsaw and 3/4 mdf, pine or whatever wood you have lying around, they won't be seen but you want to make sure there rigid and wont fall apart. or:
http://cgi.ebay.com/BEST-KITS-BKSG60...#ht_2944wt_912
Old May 4, 2011 | 08:38 PM
EG FTW's Avatar
sounds like a good plan ill definitely try this tomorro morning and see how it goes. thanks for the help!
Old May 5, 2011 | 03:53 AM
0c00l's Avatar
Anytime bro
Old May 7, 2011 | 01:21 PM
fcm's Avatar
fcm
Old Fart
For Best SQ replace the stock plastic speaker housing with a custom MDF speaker plate, use the stock housing as a template and cut it out of 1/2" MDF, drill mounting holes to line up with stock holes, cut out speaker hole, big enough for speaker magnet plus a little, then add whatever height you need to get the mounting depth you need for the speaker using MDF spacers.
The mounting plate needs to be shaped like the stock housing but the spacers can just be round, OS diameter the same as speakers overall diameter and the speaker mounting hole, [IS diameter] to match the speaker, you can use diff. thickness of MDF to get the correct mounting depth.
The 3 main rules for mpounting speakers are...
Airtight seal between front and back of speaker for at least the diameter of the speaker from the edge of the speaker, lower speaker F3 point, [better bass].
Absolutely flat surface for mounting speaker, twisting/warping the speaker basket will misalign the speakers VC.
The more mass the better, as speaker mounting plate made of MDF will have a lot more mass then the stock plastic speaker housings. 94
Old May 10, 2011 | 09:00 PM
EG FTW's Avatar
wow never thought of trying that either. maybe this weekend if i have any spare time ill try making new mounts out of MDF or at least see what i wanna do next. thanks for the info its been very helpful!
Makdaddynuge
Audio / Security / Video
11
Jul 24, 2008 04:45 PM
NateSVT
Nov 3, 2007 04:39 PM
coyote
44
Oct 1, 2007 03:54 PM
cyang1
Feb 20, 2007 05:08 AM
Fliplm0de
Jul 30, 2006 12:01 PM
