intermittent starting problem.
Old May 4, 2011 | 09:34 AM
ef8sleepr's Avatar
Default intermittent starting problem.
o.k it's a 91 crx si. I get in the car and try to start it and it just keeps cranking like there's no fuel delivery. I check the spark, and it still there. so I'm assuming its the fuel system. But check this out. sometimes I just get in the car and it starts up just fine. And it'll start up for months and months. then a hick up and it won't start. If it is the pump since I don't hear the priming when I turn the key on or the pump is just hella quiet, is this a dropping the tank fuel pump removal or I can get it from up top inside the car?
Old May 4, 2011 | 09:36 AM
Nooch's Avatar
Default Re: intermittent starting problem.
Have to drop the tank. It's easy so don't sweat it, just have a jack bracing it up because there's a few wires/hoses that you don't want to get torn.
Old May 4, 2011 | 11:05 AM
jtwellner's Avatar
I have the same problem with my 91 Si. I have narrowed down the problem to either a relay that turns on the fuel pump when the key is on or the ignition switch itself. Trying a different relay now but not sure if it is fixed or not. Definitely pay attention to the fuel pump though as that seems to be what isn't powering on.
Old May 4, 2011 | 11:21 AM
90efhatch's Avatar
I had that same problem in my 90 SI and in my 93 coupe. The coupe eventually never started again after a long trip, I had spark but I could not hear the fuel pump prime. Before I changed out the fuel pump I tried my friends ECU and it started right up. There is a capacitor in the ECU that goes bad that goes to the fuel pump. I am guessing it was the same problem on my SI so I am converting it to OBD1 with a new motor.
Link to the thread
https://honda-tech.com/forums/engine-management-tuning-124/chipped-p28-not-priming-fuel-pump-1159611/
Old May 4, 2011 | 12:29 PM
jtwellner's Avatar
thanks. I will be cracking my ECU to check soon.
Old May 4, 2011 | 12:32 PM
ef8sleepr's Avatar
thanks for the input. I shall try the switchero with the ecu method since it's the easiest to do. then go from there.
Old May 4, 2011 | 01:30 PM
gringo7718's Avatar
Try to check the Main Relay.
http://techauto.awardspace.com/mainrelay.html
Old May 4, 2011 | 01:54 PM
rrandol5's Avatar
Same sort of thing happened to me the other day. Turned out I had water in the distributor.
91GEDHATCH
Sep 30, 2011 02:53 AM
kuckimonster2
Jul 25, 2005 07:03 PM
spettinger
May 25, 2005 11:46 AM
Civichatch27
Jun 19, 2004 09:22 PM
