timing belt valves maintenance
I will get my timing belt changed and valves adjusted from the workshop. The car has no problems. It is 98 crv with automatic gear. What parts will I need please give complete list.
Water pump
Coolant
(all outside drive belts) Alternator/power steering/AC
that is all for timing belt
For valve adjustment you will need
Valve cover gasket set w/ plug o rings
grey hondabond (RTV silicone)
I would recommend spark plugs because oil usally gets all over them ( this sometimes is also replaced with timing belt jobs)
timing belt
water pump
camshaft seals
fr crankshaft seal
drive belts
valve cover gasket and grommets
coolant
Tensioner optional- I've only seen a handful actually go bad over 10 years.
Use OEM parts/fluids.
water pump
camshaft seals
fr crankshaft seal
drive belts
coolant
timing belt
water pump
camshaft seals
fr crankshaft seals
drive belts
coolant
i would ADD to this, the cam seals as well, since its apart that far, its not much more to put these on
water pump
camshaft seals
fr crankshaft seals
drive belts
coolant
do you guys replace the timing cover seals? Or only if they're completely tore up when it comes apart?
I know this is kind of an old/dead thread?
BlitzSix
Feb 16, 2009 02:47 PM
doostin
Feb 1, 2009 04:45 PM
