How do I check the quality of a ground?
Old Sep 29, 2002 | 03:50 PM
jweller's Avatar
Default How do I check the quality of a ground?
I've got some general weirdness going on with a turn signal bulb. bulb does not work in the socket, but does work when hooked up to a 12v source. i show 12v at the socket for the bulb on the hot side. I also show continuity between the neg post on my battery and the ground wire at the socket. i'm wondering if there is such a thing as a ground that isn't good enough, and how would I test it?
Old Sep 29, 2002 | 03:51 PM
fixhondas's Avatar
Default Re: How do I check the quality of a ground? (jweller)
To test a ground put a voltmeter between the suspected bad ground and a known good ground. You should have LESS than 0.05 volts.
Old Sep 29, 2002 | 03:52 PM
Archidictus's Avatar
Unceasing Measure
bad ground could absolutely be the problem. unfortunately, the best way to test it is to get another wire (new, preferably) and wire it up. see if there's any buildup of gunk on the ground point and, if so, steel-wool that badboy (wirebrush is good too) til you see shiney metal
Old Sep 29, 2002 | 06:09 PM
lightning's Avatar
Default Re: How do I check the quality of a ground? (fixhondas)
You can also check the voltage at the light with your load (lightbulb) attached. Check the voltage using the ground for the bulb as well as the hot for the bulb as the connection points for the multimeter. With the load connected, the voltage will "drop-out". Do this first then use the technique from the previous post checking for voltage between the grounds. If you get a voltage drop and the ground test shows good, then you have a power supply problem and not a ground problem.
Old Sep 29, 2002 | 06:20 PM
jweller's Avatar
Default Re: How do I check the quality of a ground? (lightning)
OK cool. Thanks
Old Sep 29, 2002 | 09:45 PM
BudaKai's Avatar
Or just use the tongue method. j/k
B_Swapped93
Apr 30, 2013 03:15 PM
dan12288
Lighting
Feb 3, 2008 12:20 AM
CptCorN
Apr 15, 2005 12:47 PM
Fatty_1775
Audio / Security / Video
Aug 25, 2004 06:57 AM
ferio 95
Jul 30, 2003 10:13 PM
