oem retainers wear !
Old May 3, 2011 | 12:01 PM
todahead's Avatar
Default oem retainers wear !
i opened my valve cover due to check valve train and valve lash i saw this !
everything in the valve train is stock i was hearing a small tap tap but nothing too crazy to worry about.
what can caused this wear ?
also is too dangerous to drive my car now (drop a valve)?
Old May 3, 2011 | 08:46 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: oem retainers wear !
doesn't look too bad. my h22 was way worse. your lma's could be bad and let the middle rocker slam down on the retainers.
Old May 4, 2011 | 07:01 AM
todahead's Avatar
my engine can break any moment !
what retainers to go for oem or supertech ti with their springs ?
i'll use stock cams.
Old May 4, 2011 | 07:17 AM
bambam's Avatar
I would disassemble the head and inspect. Figure out what's causing your wear. Titanium retainers are a good upgrade, but you may end up in the same boat if you don't find the cause. Worn lmas are a possible cause as the previous post states.
Old May 4, 2011 | 09:04 AM
96dxB16's Avatar
don't the Ti retainers actually wear quicker than the OE ones?
Old May 4, 2011 | 10:13 AM
1998GsRIntegra's Avatar
Yes
Old May 4, 2011 | 11:15 AM
mar778c's Avatar
Community Builder
Community Influencer
No, Ti does not wear quicker than any other retainer. A retainer must snap fit with the spring, regardless of construction material. Ti's problem is lack of endurance limit.
Old May 4, 2011 | 03:39 PM
Please define endurance limit for those of us who dont build engines on a daily basis.
Old May 4, 2011 | 03:54 PM
mar778c's Avatar
Community Builder
Endurance limit is an engineering term where below a certain amplitude of stress the material can go thru a near infinite number of cycles.
The blue line shows an example of endurance limit for steel. The red line for the aluminum shows no limit. Thus you are cycle limited. If you have a very well defined stress regimen the problem is managed. The best example is for aircraft frames or gas turbine blades. Those are constantly monitored and removed from service after X number of hours.
Old May 4, 2011 | 04:10 PM
Good stuff. Unless of course your south west airlines. They just run **** until it breaks. Lol
So basically as long as a material isn't subjected to more stress than it can handle it will last for a long time?
Your dealing with a 17 year old so laymans terms are better. Lol
Old May 4, 2011 | 04:24 PM
mar778c's Avatar
Community Builder
Yes, that is correct. As long you are below the flat line, you are golden.
DerekHollister
Engine Machining & Assembly
Sep 23, 2015 02:36 AM
Natural Aspirations
Feb 6, 2014 03:35 AM
Legion
Aug 9, 2007 11:23 AM
existanzcivicb20
Apr 12, 2006 01:30 PM
Pearl Crx
Oct 13, 2005 08:45 PM
