Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 clutch problem
Old May 3, 2011 | 11:33 AM
h22 kid's Avatar
Default 2001 clutch problem
ok i just changed the clutch on my civic along with a new master and slave, and when i go to bleed it im there for hours.... keeps hitting the floor. i mean theres nothing to bleeding a system, done it several times on other vehicles and worked fine but for some reason im having trouble here. fluid is coming out fine and no more air in the system, just having an issue building pressure for the pedal to retract and engage and disengage the clutch... any help would be quite useful.
p.s. i've searched for two days and used several methods, now i come here to seek more advice.
Old May 3, 2011 | 02:16 PM
lazlong's Avatar
Default Re: 2001 clutch problem
Any visible leaks? Did you replace the O-rings? Did you grease the slave cylinder properly? Maybe the new master or slave cylinder is bad.
Old May 3, 2011 | 03:05 PM
h22 kid's Avatar
Yes yes yes yes and yes lol. I think my mc is bad. I'm going to exchange it. Then see what's up
Old May 3, 2011 | 03:34 PM
civichxtreme2's Avatar
Reverse bleed it......Open the resevoir and take small hand help pump to the slave cylinder bleeder valve...pump fluid in from the slave cylinder and I guarantee you wil have bubbles floating to the top of the resevoir. Its worked for me when all else has failed. Ive had to do that twice on 7th gens
Old May 3, 2011 | 04:33 PM
h22 kid's Avatar
hmmmm. where can i get one of those devices?
Old May 4, 2011 | 08:38 AM
Any auto parts shop usually carries them.......Its just the small can with a lil pump on the top....they are very common
Old May 4, 2011 | 09:28 AM
2002civicrider's Avatar
How are you bleeding it? The way I did it was put a hose off the bleeder into a bottle or cup of fluid. Make sure it stays submerged at all times. Crack bleeder open and keep pumping it. And make sure you never run the reservoir empty. I changed out my slave a few weeks ago. Took about 15 minutes for it to get pressure back into the pedal.
Old May 4, 2011 | 09:52 AM
h22 kid's Avatar
Exactly the same procedure. But won't gain pressure at all.both slave and mc cylinder are the new
Old May 4, 2011 | 05:50 PM
Try it my way, ive use it several times and its never failed me.
Old May 4, 2011 | 08:34 PM
With the bleeder open manually move the fork a few times in between. I did that a few times. I've seen clutch bleeding take up to 2 hours before.. It's a bitch to do.
Old May 5, 2011 | 07:27 PM
mK<3's Avatar
exact same thing happened to me i had to replace the lines
Old May 7, 2011 | 12:59 AM
h22 kid's Avatar
havent tried that yet, but will keep it in mined
i've done that and still nothing.
how did you figure the lines were bad??
Old May 7, 2011 | 08:37 PM
The lines dont really go bad unless thy are swelling or leaking, both of which you will be able to visually see. You have air in your lines I guarantee it, it needs to be bled more and properly. If all else fails get it to a shop that can fo this for you.
Old May 9, 2011 | 09:24 AM
mK<3's Avatar
we used a pressure gun to check if we had it and we didnt so we knew we had a leak somewhere on the line... once we replaced them we had it!
Old May 9, 2011 | 11:52 AM
h22 kid's Avatar
i was thinking about it, but i read also on a different forum, some guy said that the rubber hose line cracked and expanded to much that it lost pressure and wasnt building pressure to help retract the pedal, but then again idk how true that is.... i might just exchange the master and see whats up
Old May 9, 2011 | 05:07 PM
ken9's Avatar
Must be a leak somewhere on the fluid lines..
Old May 10, 2011 | 08:12 AM
h22 kid's Avatar
no fluid is coming out on any of the lines
Old May 10, 2011 | 10:43 AM
Are you still screwing with this a week later, Just take it somewhere and have someone properly bleed this thing
Old May 10, 2011 | 04:30 PM
h22 kid's Avatar
i havent touched it in 4 days, im to busy with finals right now. most likely im just going to take it to get done.
Old May 10, 2011 | 07:15 PM
Yeah I hear that, at this point that should be best
Old May 16, 2011 | 05:06 PM
mK<3's Avatar
i ended up changing the master once an the slave twice. my bet is on those lines u probably have a leak somewhere. theyre almost unnoticeable.
Old May 17, 2011 | 12:43 AM
h22 kid's Avatar
ok my question is why all of a sudden would it just not hold pressure and before the entire change it was fine? why was i not having problems sooner?
Old May 17, 2011 | 12:32 PM
lordhelmet1584's Avatar
Did you bench bleed the MC?
Old May 17, 2011 | 07:13 PM
h22 kid's Avatar
yeah i did
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
rehab_this
Aug 22, 2007 10:18 AM
importfanatic17
Jan 1, 2007 10:00 PM
karmadhi
Oct 9, 2006 03:12 PM
Hard2Find
Mar 12, 2002 03:17 PM
