Wiring problem please help:-(
Old May 3, 2011 | 10:05 AM
crxb16a90's Avatar
Default Wiring problem please help:-(
2002 rsx type , got this car not running, got it running few days ago, there's was burn wire on engine harness so I repaired it, still wouldn't start, then we pull the battery from the truck(relocated) and move it back to the front, then got power to ecu, now only problem having, door lock will not work when key off, keyless will not work when key off, it could due to same problem, if u have ur light on turn off the key, the dash light will turn off, and also blower fan not work either, so I m thinking when engine harness short out, it took out a ground or power, so not enough power to run them, anyone some reason went thu that?
KINGFLIP
Apr 12, 2015 04:25 PM
importdude2000
Audio / Security / Video
Sep 29, 2006 09:38 AM
jsteplasy
Sep 28, 2005 04:16 PM
Integer
Apr 20, 2005 08:44 AM
