Getting out of hondas sale! -Lafayette, LA
Parts located in Lafayette, LA ...all prices are picked up (motor/transmission pick up only) and shipping will need to be estimated per item
You can contact me via pm's or through tommytheriot87@hotmail.com
<used 2000 miles>Full-race B series Manifold (old style with straight wastegate pipe) New $1250 My Price $800
<new>Skunk2 EF short shifter New $120 SOLD
<new>Skunk2 B vtec pro series std valves (intake/exhaust) New $300 My Price $260
<new>Skunk2 B vtec Tit retainers New $207 My Price $170
<new>Skunk2 B vtec Tuner series valve springs New $220 My Price $185
<used>Skunk2 B vtec Pro 1 cams New $665 SOLD
<new>SuperTech Valve guides B series vtec (intake/exhaust) SOLD
<new>Rywire OBD0 to OBD1 conversion harness New $104 SOLD
<used>GSR stock cams (one small nick) My Price $50
<new>ARP GSR/Ls-vtec head stud kit SOLD
<used>Skunk2 B vtec cam gears New $230 SOLD
<new>Cometic Head gasket 81.5mm (ls/v) New $80 My Price $60 <-free with ls/v motor
<5000miles>Hasport EF B series motor mounts (has small rubber missing but shouldn't effect) New $333 My Price $250
<used>Unknown EF B series shift linkage New $125 My Price $75 <- 50 if bought with motor mounts
<5000mile>B18a1 bottom B16a1 head LS-vtec engine. Bored 81.5mm, Stock head, JE pistons, eagle rods, stock crank, edelbrock victor x manifold, dsm injectors, unknown fuel rail. Transmission is LS cable with OBX lsd (still not broken in yet) 6 puck clutch and aluminum flywheel. Asking Price $2000.00
<used>Hondata S200 w/ boost (Missing cable to pc)My Price $200
<used>Apexi VAFC w/ My Price $100
<new>Blox TPS B series New $40 My Price $30
<new>Golden Eagle B/H DOHC cam seal New $24 My price $15 <-pickup only, free with ls-v
<new>OBD1 Distributor (was going to convert ls/v to obd1) SOLD
If you buy the next 3 items (breather setup) I'll do $350 plus shipping for it all.
<new>Go Autoworks B series block fittings for catch can New $60 My Price $45
<new>Go Autoworks Catch Can New $190 My Price $175
<used>B16/B18 valve cover painted wrinkle red and welded bungs for catch can (need to dremel out one or two of the bungs)My Price $150
<new>Skunk2 Upper Control Arms for EF civic/crx (http://www.skunk2.com/mm5/merchant.m...de=516-05-5660) New $230 My Price $190
Only thing wrong with the valve cover is when I bought it, one of the bungs were not dremel'd or drilled open. The guy had it welded on and the valve cover repainted. Not hard at all if you handy with a hand tool!
How much would you do for the catch can and valve cover? Is the catch can the same style as the t1? 4 for valve cover, two for block. Block also doubles as a drain back
This is the catch can : http://www.go-autoworks-store.com/gogtoilcaca.html
4 for the valve cover, 2 for the block. PM me a zip code and i'll give you a quote on everything. The 3 fittings, although pictured are separate.
Thanks,
Tommy
Thanks,
Tommy
MmMmm...now that the vr4 is home I just wanna get this manifold ordered.
So...until I actually buy my manifold, I'll let the engine/transmission/manifold go for $2500 picked up no shipping.
Decide to buy more, I'll go cheaper lol
Cams are pending sale
2500 for engine/transmission/mounts for ef/shift linkage for ef/valvetrain with gsr cams, full-race.com manifold.
pretty much everything but the breather setup/distributor/s200/vafc
but i'll throw in everything for 2800!
Bump - get off work tomorrow morning!
Sorry I haven't answered pm's and e-mails...was busy moving before I came to work and have been busy since.
The cam seal, unless sold locally, I'll just give to the person that buys my motor. Been getting hella lowballed on it due to Ebay -.-
hatchetmancivic
Jul 21, 2011 12:54 AM
thornton22050
Jan 6, 2009 05:10 PM
