how do I tell if a used catalytic is good or bad?
My 99 civic didn't come with a cat when I bought it. I got a used one I want to throw in. Any way I can test it to make sure it works fine? shake it? try to blow air through it?
look down thru it and see if the porcelain honeycomb is solid all the way through and has no holes in it and u can not see through to the other end.
Hello,
I am new to the forum and need help. I have a 1998 Honda Civic DX Automatic (4 door) with 144,000 miles in Illinois.
My check engine light came on and I took it to my mechanic. He quoted me the following to fix it:
(1) CAT Converter (Part -$710) & (Labor - $128)
(2) Pre & post 02 Sensor (Part - $241) & (Labor - $23)
I feel like he is trying to screw me. He said they were rusted, and I think something about a manifold. I am an accountant and not a mechanic, so I am not that familiar with some of the things he was saying.
Can someone help guide me in the right direction?
I've also noticed an unusual rattling noise around the same time as the check engine light, is this related?
Is this the parts that I need?
http://www.1aauto.com/1A/CatalyticCo...tm_content=EEM
Thank you all for any info you can provide.
Hello,
but if you want to be certain to pass years down the road, get this one:
http://www.amazon.com/Dorman-673-439-Exhaust-Manifold-Kit/dp/B001NYNPTU/ref=sr_1_2?ie=UTF8&qid=1304393881&sr=8-2
You need the more expensive one if your area has "California emissions" or if you *hint hint, live in California..
ejulson
Mar 5, 2012 06:52 AM
freddysEF
Feb 11, 2008 08:59 PM
yairsaenz83
16
Feb 18, 2007 05:58 PM
thor1967
Dec 15, 2004 09:56 AM
