Waterneck question : WHAT is this?
Old May 2, 2011 | 11:16 AM
eghatchfla's Avatar
Default Waterneck question : WHAT is this?
i just put an ls in my car and i need to know what this tube is and if a line runs to somewhere?
plz help
Old May 2, 2011 | 11:23 AM
adio8352's Avatar
Default Re: Waterneck question : WHAT is this?
its a vacume line that sould run back to your lower radiator hose follow your radiator hose from the bottom of the radiator back of the motor and there should be another addapter that looks like the one in your picture and just run a hose to it.
Old May 2, 2011 | 11:32 AM
eghatchfla's Avatar
i didnt find one..can it just be blocked off?
Old May 2, 2011 | 12:41 PM
eghatchfla's Avatar
bump
Old May 2, 2011 | 03:24 PM
dntnedvtec's Avatar
That looks upside down. That hose should be the other way towards the Intake Manifold. It connects to your Fast Idle Thermal Valve, or your Idle Air Control Valve. But what bugs me is that, it lines up......
Old May 2, 2011 | 04:18 PM
fcm's Avatar
fcm
Old Fart
Pretty sure it is not a vacuum.
What is the MM&Y of the car or the car the engine is out of if a swap? 94
Old May 2, 2011 | 06:50 PM
eghatchfla's Avatar
its a 97 ls in a 2000 integra. I dont think it would be vacuum either cause water comes out of there..
Old May 2, 2011 | 11:14 PM
senser1080's Avatar
It's for bleeding the coolant systems. Do none of you have a haynes manual?
Old May 3, 2011 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by senser1080
It's for bleeding the coolant systems. Do none of you have a Haynes manual?
Yes I have a Haynes, so exactly where would I put the wrench to undo the air bleed bolt??? 94
Old May 3, 2011 | 08:04 AM
shocker911's Avatar
it runs to your fast idle valve....if you have something running to that already you can T into that line with that one and you will be fine.
Old May 3, 2011 | 08:18 AM
mouab18c1's Avatar
Lulz, it's funny when people underestimate your smartness on these cars.
Old May 3, 2011 | 05:52 PM
pakn-heat's Avatar
Ya.suposed to be like a little nipple thing to bleed it.but looks like it maybe been bootlegged..
Isn't the one for the ftiv come out the side of head or somthin like that?
Old May 3, 2011 | 05:57 PM
pakn-heat's Avatar
I would just cut small peice of hose and slip it on and put a bolt on other end and get hose clamp..lol
Or try and unscrew it and get the nipple thingy,or find a bolt and screw it in insead of that
Old May 3, 2011 | 07:11 PM
fcm's Avatar
fcm
Old Fart
eghatchfla Your thyermostat housing is upsidedown that "nipple" should face to the back and down, bleeder valve should be at the top front.
A hose [#6] runs from "nipple to a metal tube attatched to another metal tube, [breather heater, sorry no part #] that runs from valve cover to IM, from that metal tube another rubber tube runs to behind the engine, on pass. side, to the nipple to the left of hose #3 on lower rad hose housing... http://www.acuraoemparts.com/delray/...All&vinsrch=no 94
Old May 4, 2011 | 01:16 PM
dntnedvtec's Avatar
Thats what I said.....
liquidx
Aug 21, 2010 10:02 AM
96WhiteOnBlack
Apr 5, 2007 08:01 AM
billy hoang
Jan 21, 2007 01:17 PM
forever slow EG6
Jun 21, 2003 10:14 AM
