Help me find a suitable catch can
Old May 2, 2011 | 09:08 AM
brenth's Avatar
Default Help me find a suitable catch can
Hi everyone
Im about to do a proper catch can setup on my ITR race car.
I already have a rocker cover with 2x -12 sized fittings welded onto the front and also a Full Race PCV bung so all i need now is the actual catch can and fittings and line.
The fittings and line are easy to come by but I can't seem to find a suitable catch can. I need one at least 1L in volume (NZ motorsport regulations), one that has a proper breather filter on the top (with the tube that goes 2/3 of the way down into the can), and one that has 2x outlets (can be either -12 or 1/2 NPT as I can get adaptors to change it to -12), preferably both fittings on the same side, one below each other.
I've seen the Moroso, AMS, and a few other cans and they are so close to what i'm after, but not quite. What other off the shelf cans are available?
Links would be appreciated.
Thanks in advance
Old May 3, 2011 | 10:06 AM
bmxkills's Avatar
Default Re: Help me find a suitable catch can
You're gunna get people on your ***, because honda-tech is full of smartasses... But, I made a thread recently about this, and I ended up doing my own eBay can... Get a decent looking, functional catch can off of eBay. They're all hollow, so you need to add baffling. I added stainless steel wool scrubbers so it won't deteriorate. I added drilled the holes provided (mine were too small), and added my own bigger fittings. Then, I went to the local hardware store, and got reinforced clear tubing. Then just run those hoses to the can and call it a day. I ran my catch can setup to the back of the block however.
Old May 3, 2011 | 06:12 PM
stumpyf4's Avatar
Check out the endyn kit. My can has the fittings welded side-by-side, not stacked like the picture. If you don't need all the stuff in the kit you may contact them and ask for the can only.
http://www.theoldone.com/components/breather/
Z10 Eng also makes a nice can.
http://www.z10eng.com/catalog/produc...products_id=35
T1 catchcan requires moving the battery but is another solution. I think they can make custom cans too.
http://www.t1racedevelopment.com/ind...atch-cans.html
almostjdmeg
Mar 29, 2010 06:22 PM
slowhitEJ1
Aug 30, 2009 08:38 PM
jdmcivicferio
Jun 10, 2004 04:34 AM
