Transmission & Drivetrain Gearboxes, Differentials, Clutches
Stage 1 clutch? B16 , CRX SIR tranny.
Old May 2, 2011 | 01:20 AM
Non Phixion's Avatar
Default Stage 1 clutch? B16 , CRX SIR tranny.
I have a b16 hf crx with a SIR tranny,
I have a stage 3 clutch masters in it but I've gone through 3 pedal assembly's and 2 clutch cables so I have to install a less aggressive clutch.
I think I should be fine with a stage 1 clutch.
Any recommendations on what type I should get?
And also how do I know how to order the right one that would fit the engine/tranny I have?
Old May 2, 2011 | 03:14 PM
Gearspeed-Performance's Avatar
Default Re: Stage 1 clutch? B16 , CRX SIR tranny.
What is the Trans ID# code?(gold or white sticker on trans) If it is Y-1, S-1 or J-1 get a clutch for 90-91 Integra. If it is a YS-1 then you can get a clutch for a 92-up Integra.
Depending on what kind of driving you do a stage 2 might be able to handle a little more aggressive use and still be easier as far as engagement vs. a stage 3.
Old May 2, 2011 | 04:45 PM
The car is a dd but I like to race a few ppl in town and hopefully get to autox it someday which is why I was thinking to just do a stage 1 clutch. Do I have to lift the car to see the tranny code?
And can I keep the flywheel that's with the stage 3 that I have and use it with the new clutch?
LU!SKEY
Aug 19, 2010 10:23 AM
KDvtec5757
Jul 13, 2008 01:56 AM
Dave_yd
Mar 26, 2008 04:23 PM
vlc92189
Nov 20, 2007 09:05 PM
iBrandon
Jan 29, 2005 03:42 PM
