FS/FT: 94 hatch, AEBS, TWM, Brian Crower, MAHLE, ALL MOTOR BEAST, Enkie
Worst case the block sunk a sleeve, or it could be a head gasket, IDK, I'm not sure exactly...worst case the block would need to be re-decked. The motor was never ran hot... I checked my fluids everyday before I drove my hatch and the other morning when I was checking the oil and coolant, I noticed it was low on coolant, and when i checked the oil i found the missing coolant. The day before all fluids were checked and everything was fine, and when i returned home the car was fine no noises, misses, or smoking. This is your chance to get a fully built car for extremely cheap. i have put extremely too much time and money in the car, and can not afford to put anymore in it. I could part it out and probably get more than this but i have found another car and need to get it asap, due to the hatch being my dd.
I have a 94 eg hatch for trade or sale, I have owned the car for almost seven years, and have spent the last 1 1/2 years putting together the current build. the motor and all internals have around 1k miles on them. It is an all motor build making 232 whp and 161 ft lbs of torque. on to the list:
Motor:
b16 head
Brian Crower stage 3 cams
All Brian crower valve train as well
skunk2 pro series cam gears
custom valve cover
50mm twm itb's
GSR block 85mm
AEBS t sleeves
Eagle H-beam rods
MAHLE 12:1 cr pistons
new oem water and oil pump
new oem timing belt
xenecron fuel pump (same as walboro)
Innovative motor mounts
samco radiator hoses
Tranny:
gsr tranny w/ LSD
Competition Clutch stage 3
dual bend shifter skunk2 ****, spoon one as well
Exhaust:
2.5'' greddy evo catback
profab header
Wheels, Suspension, & Brakes:
16 x 7 Enkie Rpf1's mint
205/45/16 yokohama parada spec II (new)
Tein basic dampeners
itr lcas
itr front calipers, gsr rear disc
skunk2 lower tie bar
skunk2 front camber kit
Exterior:
carbon fiber hood and duckbill
oem jdm eg6 headlights
amber corners and sidemarkers
Interior:
GSR leather seats front and rear (drivers seat has some wear, rears and pass are in great shape)
jdm eg6 cluster
jdm eg6 floormats
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
pm for any questions or more pics
Motor:
b16 head
custom valve cover
50mm twm itb's
GSR block 85mm
AEBS t sleeves
Eagle H-beam rods
new oem timing belt
Tranny:
gsr tranny w/ LSD
Exhaust:
profab header
itr lcas
Exterior:
Interior:
jdm eg6 cluster
jdm eg6 floormats
[IMG]
[/IMG] [IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]pm for any questions or more pics
NA is expensive but I respect the hell outta it! turbos are just cheap power anymore and everyone does it for that reason!! Bump for a nicely done eg...would buy it bought just bought an si, keeping mine NA as well
