93 dx bad idle please help changed the iacv
Old May 1, 2011 | 07:15 PM
SPITVENOM67's Avatar
Default 93 dx bad idle please help changed the iacv
ok so Idle jumps up and down at stop lights no matter if its warm or cold, drives fine on the freeway. I changed the IACV today and its still doing it. unless I got a bad iacv it something else? no vacuum lines are disconnected . help me out
Old May 1, 2011 | 08:21 PM
Default Re: 93 dx bad idle please help changed the iacv
cmon guys
Old May 1, 2011 | 08:31 PM
Spoon84's Avatar
Have you jumped for any codes?
Check for any vacuum leaks. Whip out a can of starter fluid and spray all the gaskets, injector gromets and vaccum hoses you see. You never know.. could be something real small not noticable.
Old May 1, 2011 | 09:04 PM
its not throwing any codes, its also very jumpy and not smooth, you can tell when you let go of the gas or your in 1st gear the car is jerky .
Old May 3, 2011 | 09:55 PM
tried a new iacv from autozone and no luck..can it be the ecu?
Old May 3, 2011 | 10:48 PM
Draiga1988's Avatar
i actually currently have that issue as well when thecar is sitting still even in neutral it idles from 1500 rpm to 3k or less then repeats. Im sure mine is a vaccum issue though cause i drove for 3 hours straight an got out an my intake mani was cold to the touch. So im just going to get a y8 intake an throw that on there with all the hoses replaced an see if that fixes it. cause i had replaced TPS an the IACV an that did nothing.
Old May 4, 2011 | 03:29 PM
anyone cmon HT
Old May 4, 2011 | 03:53 PM
panchlow's Avatar
try with that guy said.
spray sum started fluid into ur hoses and gasket wer air passes thru'
if the car rpm's change then change the hose or the gasket.
or clean that thing(i forgot whats it call) under ur throtle and check if that works..
If it still does it..
Take in to pepboys for a vacumm leak test for 80$ and they will let you kno.
Thats if you dont want to play the guessin game.
Old May 4, 2011 | 07:56 PM
Draiga1988's Avatar
lol guessing game, story of my life.
95brazile
Feb 28, 2011 12:11 PM
alacard
Jun 3, 2009 11:25 AM
looxs
Nov 1, 2006 09:09 AM
ccjustin
Nov 9, 2005 06:29 AM
Krayzielix
Dec 31, 2004 05:53 PM
