FS: CIVIC INTEGRA & RANDOM PARTS!!! UPDATED REGULARLY
Located in West Palm Beach
Call or text anytime 561-315-3710
Acura Integra Type R or GS-R ARP Head Studs they fit B18C, B18C1, and B18C5 engines and come with all the washers and nuts.
I also have Arp head studs for B16's and Ls/B20 Vtecs - $75
Acura Integra GS-R cams removed from a 2001 GS-R. They are in good condition and come with aftermarket aluminum AEM cam gears. Will fit all B series Vtec engines - $100
Driver side axle removed from a 2000 Honda Civic Ex in good condition with no rips. Will fit all 92-00 Honda Civics - $30
Mint condition Honda Civic dark gray ignition covers, will fit all 96-98 Honda Civics - $30
96 97 98 Honda Civic rear bumper will fit all 96-98 coupe and four door Honda Civics - $40
Honda Civic Si 99-00 P2T 5 spd manual ECU B16A2 Vtec OBD2B in perfect working condition - $50
Honda Civic power window switches removed from a 96 Civic coupe - $40
96-00 Honda Civic antenna in very good condition - $30
Honda Civic Injectors and Fuel Rail in good condition removed from a 96 Civic - $40
96-00 Honda Civic Coupe Trunk Lid in Good Shape with No Wing Holes or Any Dings or Dents - $40
96-98 Honda Civic 4DR Trunk Lid in Good Shape with No Wing Holes or Any Dings or Dents (lights not included but available) - $40
99-00 Honda Civic Si Left Front Brake Caliper removed from a 2000 Si and it is in good condition (passenger side caliper also available) - $25
93-95 Honda Civic Coupe Trunk Lid with No Wing Holes - $40
OBD2A Acura Integra Engine Harness complete and uncut that was just removed from a running 1999 Acura Integra Ls (OBD1 harness also available)- $100. Will also fit 92-95 Civics with obd2 engine swap to make it easier.
94-01 Acura Integra/99-00 Civic Si A/C Bracket will fit all 94-01 Integra's and 92-00 Civic's with DOHC - $30
94-01 Acura Integra Engine & Transmission Mounts, will fit 94-01 Integra's and 92-95 Civics with DOHC or EX SOHC. They are in very good condition and I also have the rear mount which is the same from 92-00 for civics and 94-01 Integra - $25 each
94-01 Acura Integra Cast Iron Cam Bracket will fit 94-01 Integra's and 92-95 Civic's with DOHC - $30
99-00 Honda Civic Si / 94-01 Integra Flywheel, disc, and pressure plate good condition - $100
Acura Integra Adjustable Camber Kit with control arms will fit all 94-01 Acura Integras and 92-95 Civics. The ball joints in the control arms are good and the boots are not ripped - $40
94-01 Acura Integra OEM Air Filter Box & Rubber Elbow - $40
94-01 Integra Driver Side Door Glass - $25
02-04 Acura RSX Type S I-VTEC Engine Cover - $40
02-04 Acura RSX Type S Gauge Cluster miles are unknown but probably low I’ve had it for years - $80
Acura RSX Black Center Console with working cup holder & tray. It comes with the shift boot as well - $50
02-06 Acura RSX Black Passenger Side Kick Panel - $10
98-02 Honda Accord 4 door Rear Bumper - $40
96-00 Civic Door Shells - $50 each
96-00 Civic Coupe or Hatchback passenger Door Glass - $25
96-00 Civic Coupe rear windshield-$60
94-01 Integra door glass driver or passenger -$25
94-01 Integra Doors with Glass & Regulators various years and colors (GS-R,LS) - $50 each
98-01 Integra Hatch - $50
02-06 RSX Hatch - $60
B16a and B16a2 pistons, rods, cranks, oil pumps, crank sensors, B16a blocks with or without cranks or any other B16 engine part you may need.
More Pictures & More Parts Will Be Posted
UPDATED REGULARLY
UPDATED REGULARLY
00-01 Integra engine harness and 94-01 Integra mud flaps sold to DC4Rasta. Thanks Dec!
94-01 Integra subframe, steering rack, lca's sold.
94-01 Integra intermediate shaft sold.
98-01 Integra hatch sold...still have one left
96-00 Civic black driver door shell sold...still have one red driverside left
00-01 Integra GS-R p72 ecu sold.
