FS and WTB - May 2011
Old May 1, 2011 | 04:42 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default FS and WTB - May 2011
All parts are to be ITR related or it will be removed.
All items for sale must have a price posted or the item will be removed.
If someone posts a FS price and you disagree, don't buy or comment on it.
Anyone posting multiple items please try to use one post.
Don't quote a post with pics repeated, or don't quote your own post.
Comments need to be through email or PM.
Old May 1, 2011 | 06:24 PM
somboa's Avatar
Default Re: FS and WTB - May 2011
WTB: A set (both sides) of full bucket seat rails (bc, bride, etc) for my ITR (DC2). Please let me know of anyone or any shop who has them in stock. Thanks.
Old May 1, 2011 | 06:41 PM
B00stedEh3's Avatar
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD!
FS: OEM USDM ACURA INTEGRA TYPE R CLUSTER
Product description
SOLD
Old May 1, 2011 | 07:19 PM
jahraul's Avatar
see new post
Old May 1, 2011 | 07:29 PM
99SlammedCivic's Avatar
Snipper Snapper
Parts FS:
Miracle X brace Setup w/ Optional butterfly bars- DC2 spec - $1150
Rare OEM ITR rear trunk mat - $475
Red DC5 Recaros - $1400
Black DC5 Recaro (only 1 seat) - $750
Black DC2 Recaro ( only 1 seat) - $650
Black F1 spec - carbon Kevlar w/ tdm low down rails - $1,000
Mugen mf8/mf10 Blue center caps $150
Spoon N1 Coilovers - EK spec- $1350
JDM SRS DC5 wheel - $400
OEM ITR Exhaust - $300
JASMA Fujitsu Header - B series - $350
ITR Rear Seats - $200
JDM ITR cluster - $150
ITR strut bar - $120
Shaved ITR VC painted flat black w/ bungs - $120
VOLK CF Centercaps - $150
Black F1 spec seats - wide version - $450 no rails
Shift linkage - b series - $75
Wheels:
(5lug unless noted)
\Volk CE28s - Diamond black - 16x7 - $2000
SSR Type C's Matte Black - $1600
Black Rota GT3's w/ tires - $600 or $200 plus OEM ITR's
Work RSZ-R's - 15x7 - $1400
Work RSZ_r's - 16x7 - 1 has a bad rash that is fixable - $1300
MF8's - Bronze - 4x114.3 - 16x7 - $1400 no tires or 1600 with Dunlops
Pictures can be found here:
http://www.hondamarketplace.com/show....php?t=2924958
Old May 1, 2011 | 09:56 PM
MikeY326's Avatar
WTB:
oem 98+ usdm headlights 9/10 or better if possible.
Or if someone knows where I could possibly find those for cheaper than the Acura dealership.
Thanks
~Mike
Old May 1, 2011 | 11:56 PM
4DRDB8GSR's Avatar
FS:/Possible trades:
listed asking prices DO include shipping, however DO NOT include paypal fees but PM me im always open to trades or even best offers if you're buying more then one piece, Email is SDinHD@gmail.com if you want pictures or have offers. sorry just cant load that many pictures
BNIB Eagle 5.430" GsR/ItR connecting Rods, part# CRS5430a3d - $300 shipped
Brand new MSD 8.5mm Ignition wires, Part #32349 - $95 shipped
BNIB MSD SCI-L ignition control box, Part #6320 - $175 shipped
BNIB T1R voltage stabilizer, part# 40000-VP2-P - $75 shipped
Magnecore B18C5/B series Ignition wires - $40 shipped
HardRace DC2/EG/EK Toe adjuster kit #6110 (barely used maybe 2k mi at most) - $75 shipped
Function7 Rear LCA bushings (barely used maybe 2k mi at most) - $35 shipped/set, all 8 halfs
Crower 0.5mm oversized flat faced valves, (8) 33.5mm & (8) 28.5mmmm - $60 for 16 valves shipped
Holley Fuel Rail(anodized red) with Holley FPR(silver) Rail retails for $250 and FPR at $200, so half price - $225 shipped
OEM ItR I.M. W/ IAT sensor, IACV valve, OEM 62mm ItR TB, TPS and MAF - $350 shipped
OEM ItR Rear trailing arm bushings - $40 shipped
OEM ItR rear toe/compensator arms - $40 shipped
OEM ItR front Lower Control Arms w/ bushings - $80 shipped for both
OEM ItR front compliance bushings - $75 shipped
OEM ItR front Lower control arm bushings - $20 shipped, all 4
OEM '97 Tie rod ends (sterring rack to knuckle) - $40 shipped/set, both L&R with castle nuts
OEM GsR valve springs (dual intake/ItR intake springs) - $100 shipped/set, all 24
OEM '01 ItR Lost Motion Assembly (OEM ItR LMA) - $150 shipped/set, all 8
OEM '01 USDM ItR P73 rods and pistons - $150 shipped/set
OEM ItR oil cooler with hard water line, o rings, thermostat, thermo switch & full housing - $200 shipped
OEM '01 USDM ItR crank pulley - $80 shipped
OEM '97 ItR Brake lines, front and rear - $60 shipped
OEM '97 USDM ItR ECU/P73-A02 - $250 shipped
OEM ItR chasis/engine/PS rack performance bar/rod - $35 shipped
OEM USDM ItR rear trunk/frame end performance rod - $55 shipped
OEM USDM ItR front lower sway bar w/ oem bushings and end links, 24mm -$140 shipped
OEM ItR TDC sensor, works fine just replaced since it is plastic - $25 shipped
OEM ItR/DC2 timing belt tensioner, bolt and spring - $35 shipped
OEM ItR rear and drivers side motor mounts and L,R rubber mounts - $120 shipped for the 4
OEM DC2 driver side fender liner and engine under cover - $40 picked up for both
OEM USDM drivers side axle - $90 shipped
OEM USDM ItR rear 22mm sway bar bushings - $15 shipped
OEM USDM shift linkage bushing - $15 shipped
OEM ItR/DC2 used thermostat - $15 shipped
OEM ItR/DC2 Oil dipstick - $15 shipped
OEM USDM ItR 1" Brake master cylinder - $120 shipped
OEM JDM ItR 1" Brake master cylinder - $100 shipped
OEM ItR Clutch master cylinder - $55 shipped
OEM ItR Clutch slave cylinder - $25 shipped
OEM ItR Clutch hard lines (CMC TO CSC) - $40 shipped
OEM JDM ItR front 25mm sway bar bushings - $15 shipped
OEM JDM front bumper nighthawk black pearl - $140 picked up
OEM JDM ItR front lip/chin spoiler, '01 ItR NBP color, needs re-spray probably - $140 picked up
OEM '97 USDM ItR CW lip/chin spoiler slightly cracked on front right corner but fixable - $180 picked up
OEM '97-98 ItR CW DC2 Side skirts - $100 picked up
OEM '01 ItR P.P bolts(6) - $15 shipped
OEM '01 ItR Main bolts (10) - $20 shipped
OEM '01 ItR Head Bolts (10) - $40 shipped
OEM '97 USDM ItR Fuel Pump - $60 shipped
OEM '01 USDM ItR Fuel Filter and banjo bolt - $25 shipped
OEM USDM ItR Cat. Conv. (maybe a AFR installed and then re welded?) - $120 shipped
DC Sports JDM 4-1 header (dents) - $120 picked up
CompTech CAI with filter, complete - $250 shipped
ApexI VAFC w/ all harness and manual - $110 shipped
OEM front 6-1/2" speakers and tweeters - $70 shipped
BNIB OEM ball dust boot for 92-01 Integra, 51225-SR0-A01 - $15 shipped
BNIB OEM tie rod boot for 97+Integra and more, 53546-S84-003 - $15 shipped
BNIB OEM GsR Ex. manifold gasket, 18115-P72-003 - $15 shipped
AutoMeter Pro-Comp oil pressure guage, 0-100psi - $20 shipped
OEM IiR PS pump, belt,line and reservoir - $150 picked up
Full OEM ItR AC System w pump/belt/condenser - $450 picked up
Old May 2, 2011 | 12:15 AM
Seedc2's Avatar
Boomslang OBDIIA conversion harness - 90
RC plug and play injector clip pigtails - 70
AEM UEGO with sensor - 170
New Greddy Carbon Fiber Air Diversion panel - 100
Mugen Front DC2 Bumper - 1000
Mugen DC2 second gen wing - 1200
Mugen DC2 first gen wing - 800
JDM ITR HID Headlights - 650
all parts located in socal
local pickups preferred
Old May 2, 2011 | 09:57 AM
irev210's Avatar
BRAND NEW USDM ITR Type R transmission tranny 4.4FD + LSD!
Brand new, direct from Acura dealership. 0 miles, never touched, never installed, never used! BRAND NEW!
USDM Integra type R Transmission
this has the 4.4 Final Drive and Factory LSD
Acura part # =
20011-P80-J41
Acura retail price = $2477.20
My price =
$1400 SHIPPED
Old May 2, 2011 | 10:52 AM
00ITRKid27's Avatar
OEM USDM ITR ECU PR3 175obo
Old May 2, 2011 | 12:45 PM
howl's Avatar
WTB:
JDM ITR shift boot (red stitching)
ITR rear strut bar
DC2 antenna mast or full antenna assembly
Old May 2, 2011 | 05:14 PM
DEEC2R's Avatar
FS:
BNIB Mugen MF10 Bronze 16 5x114.3 +43. $2800
Zeal Function B6 coilover - Swift Premium Race Springs 12kg/8kg used for 2500 miles. $1200
OEM ITR car cover used a couple times. Come with bag and cable lock. $225
OEM ITR checker floor mats. Minimal wear. $180
Fujitsubo Legalis R ITR spec 60mm catback exhaust. Mint condition. $550
Function 7 ITR lower control arm. Purchased new and used for 3 months. $240
JDM ITR Black Recaro set 9.9/10 super duper mint.. $2200
Prices does not include shipping or paypal fees. Pictures up this weekend.
Old May 2, 2011 | 05:22 PM
stumpyf4's Avatar
WTB:
ITR Power Steering Feed Hose, goes from the pump to the rack. Must be in good condition and need it shipped to M1H 1H9 (Toronto, Ontario, Canada)
Email: marty_ji (at) hotmail.com
Old May 2, 2011 | 06:44 PM
cleansi's Avatar
wtb jdm hood any where in the north east
text 508-525-0284 NY
Old May 2, 2011 | 08:20 PM
SJC's Avatar
SJC
WTB:
full brand new OEM red ITR interrior.... (good luck)
16" white Mugen MF10's. (NIB if possible)
I know I'm dreaming... humor me
Old May 2, 2011 | 10:32 PM
YellowKahuna's Avatar
Titanium Silver SE37K's up for sale folks. Looking to get $1700 for these. Can be shipped, as far as costs go if your serious buyer I will pay partial depending on cost. Shipping will be something we can discuss and work something out.
PM's is how to get at me.
I live in Los Angeles California
Wheel 1
Wheel 2
Wheel 3
Wheel 4
Old May 3, 2011 | 02:10 AM
Type R Teg's Avatar
For Sale:
CDM OEM Red Front seats (One has a small melt spot) Just needs a shampoo which will be done before selling. - 1250
I'm located in BC, Canada so shipping will be at your expense, or I can drive over to WA and ship them from there or potentially meet you. Pics will be taken for serious buyers.
Old May 3, 2011 | 05:56 AM
pennies_hatchie's Avatar
FS: SOLD
Old May 3, 2011 | 06:12 AM
Ronin706's Avatar
WTB:
USDM ITR Door Cards (Panels)
USDM ITR Front Lip (OEM) 98+
USDM Faux Carbon Fiber interior pieces
Old May 3, 2011 | 03:04 PM
BlueIntegraBoy's Avatar
I have two sets of UKDM/EDM/AUDM Integra Type-R front & rear red "H" emblems, new in package. I bought a few sets to offset the cost of shipping. These emblems were made for non-JDM fronts.
Price: $150 shipped (paypal gift payment only, unless you pay fees) per set
I have a BNIB Honda Access Sport Pedal Kit. Has matching dead pedal.
Price: $200 shipped (paypal payment as gift, unless you prefer to pay the paypal fee)
Old May 3, 2011 | 05:13 PM
clayton bigsby's Avatar
Originally Posted by pennies_hatchie
FS: Spoon Twinblocks with about 5k, LNIB - $1500 Shipped
holly smokes....
brand new 97 ONLY type R mask. never installed, comes with bag instructions and hardware.
$300 shipped. paypal payments only please.
Old May 3, 2011 | 05:48 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Exedy Stage 1 Organic clutch. Never used, opened the box just to take pics. Purchased for my old 97 ITR and no longer have the car. $210 shipped (shipping will kill me)
Old May 4, 2011 | 12:20 PM
beat's Avatar
FS:
Rays LE37K
17x7.5 40 offset
$1700 shipped
BBS LM
17x7.5 38 offset
$2000 shipped
Old May 4, 2011 | 11:52 PM
TypeRider98's Avatar
FS: jdm type r valve cover. $150+shipping
Paint is grease free and timing cover is uncut. has a few nicks but overall very clean.
and a few with the flash
Old May 5, 2011 | 01:02 AM
Mister DA9's Avatar
FS:
USDM ITR wheels, no caps or tires. $500 OBO, willing to ship.
WTB:
JDM ITR wheels, no caps or tires.
NHBP stock sideskirts
JDM rear seats
OEM shocks and springs
PM for quickest response.
